Graphing help - Ti89: How to graph x^2 + y^2 = 4, etc
  • Context: Calculators
  • Thread starter Thread starter nukeman
    Graph Graphing
The discussion revolves around how to graph specific equations and systems of inequalities using the TI-89 Titanium calculator. Participants seek guidance on inputting equations and interpreting the graphical output, with a focus on both algebraic and graphical methods for verification of solutions.
  • Homework-related
  • One participant requests help with graphing the equations x² + y² = 4 and x² + 2x + y² = 0 on the TI-89.
  • Another participant suggests separating the equations into two functions for graphing, providing specific forms for y.
  • There is a proposal to use parametric equations for graphing the second equation, transforming it into a circle equation.
  • A participant expresses confusion about graphing a system of linear inequalities and seeks clarification on inputting the equations x + y = 2 and 2x + y = 4 into the calculator.
  • Some participants emphasize the importance of isolating y and finding intersections algebraically rather than relying solely on graphical methods.
  • There are acknowledgments that the original poster seems to understand how to find solutions but is focused on the graphing aspect.
  • Instructions are provided on accessing the Y editor and graphing functions on the TI-89, along with tips for navigating the calculator's menu.
Participants generally agree on the methods for graphing equations and systems, but there are differing opinions on the necessity of using a calculator versus algebraic methods for finding solutions. The discussion remains unresolved regarding the best approach to graphing the inequalities.
Some participants note that the teacher's requirement to check answers without a calculator may limit the applicability of the graphing methods discussed.
nukeman
I am working on these problems, systems of equations and inequalities. Now, I know how to do the problem and find the solution set, but our teacher said that we can check our answer by graphing it without graphing calcs.
I have a Ti89 Titanium. How do I input/graph the following with my ti89:
x^2 + y^2 = 4
x^2 + 2x + y^2 = 0
Any help would be great! Thanks guys
Computer science news on Phys.org
Do it as two separate functions:
[tex]y= \sqrt{4- x^2}[/tex]
[tex]y= -\sqrt{4- x^2}[/tex]
[tex]y= \sqrt{x^2+ 2x}[/tex]
[tex]y= -\sqrt{x^2+ 2x}[/tex]
Or, set "mode" to parametric equations and use
[tex]x= 2 cos(t)[/tex]
[tex]y= 2 sin(t)[/tex]
and, since [itex]x^2+ 2x+ y^2= x^2+ 2x+ 1- 1+ y^2= (x+ 1)^2+ y^2- 1= 0[/itex]
gives [itex](x+ 1)^2+ y^2= 1[/itex]
[tex]x= -1+ cos(t)[/tex]
[tex]y= sin(t)[/tex]
I am not quit getting this here.
Lets do this one. Its for one I am more stuck on than the rest.
"Graph each system of Linear inequalities"
x + y = 2
2x + y = 4
How would I input this on my calc. I am finding the overlapping region, as that is the solution.
x + y = 2
2x + y = 4
Solve for y in both equations. You should know how to plot lines by now. After you plot the lines, you can verify that you have the correct solution by seeing where the lines intersect.
Also, reading from your original post, doesn't your teacher want you to check the answer without using a calculator? Being able to type it into your TI-89 is moot.
just isolate y, set equal to each other and solve for x, That will probably take much less time then graphing and finding the point of intersection
From reading the original post, it looks like nukeman already knows how to find the solution. I think he's just trying to graph the equations.
your right, I didnt see that.
Do as HallsOfIvy said above (separating it into two equations), and then simply press:
diamond (green key) F1, to open your Y editor.
Put your equations in there, then press diamond F3 to graph. From the graph screen you can press F2 to look through the menu options and zoom in/out, or press diamond F2 to set the window manually.
If you want to just "solve" the equations, you just have to press F2 (or is it F3) and go to solve.
If you have questions about the functions like Solve/Expand/Factor and such, just press Catalog, and scroll down to find it and it will list the arguments at the bottom of the screen when it's highlighted.
  • · Replies 21 ·
9K
  • · Replies 49 ·
