Hi, How do I find the height of the triangle , the triangle is set
The discussion revolves around finding the height of a triangle given an angle of 30 degrees and an adjacent side length of 5 meters. The subject area is trigonometry, specifically the application of tangent functions in right triangles.
  • Participants discuss the use of the tangent function to relate the height of the triangle to the known side lengths. Questions arise about the correct application of trigonometric ratios and the interpretation of the triangle's dimensions.
Some participants have offered guidance on using the tangent function correctly, while others are exploring their understanding of trigonometric concepts. There is an ongoing exchange of ideas regarding the calculations and the use of calculators.
Participants express confusion about the relationship between the sides of the triangle and the angle, indicating a need for clarification on trigonometric principles. There is mention of learning resources, such as Khan Academy and Wikipedia, which may influence the discussion.
Pin Head
Hi,
How do I find the height of the triangle , the triangle is set at 30 degrees and the length is 5 meters any help would be appreciated.
Pin Head said:
Hi,
Can you tell us what you know about trig so far? What learning resources are you using?
This page may be helpful:
http://en.wikipedia.org/wiki/Trigonometry
Hi,
I' ve been learning trig using Khan accademy
Pin Head said:
Hi,
Was the wikipedia page helpful? It answers your original question...
Pin Head said:
Hi,
Wow, that's a crazy website! So much to learn! :biggrin:
Okay I check out the wiki page and I am still a little confused ,This is what I'm thinking, is that I have to use tan = opposite / adjacent because I know the adjacent is 5 meters and I'm figuring that opposite is 90 degrees is this right
You are close. The tan(theta) = opposite side from the angle / adjacent side to the angle.
Your angle is the 30 degrees, and the 5 meter side is adjacent to it. So you have:
tan (30 degrees) = opposite side / 5m
Do you have a calculator that has tan(theta) on it? If so, you should be able to figure out the answer now. Post it for us to check...
That's the right function to use, but the opposite is the opposite side, the height you want to find.
Let h be the length of the opposite side. Now write an equation that involves the tangent of the angle you know, and the two sides, then solve for the unknown side h.
Hi,
So I use my calculator I keyed tan 30 / 5 and got 0.115470053 did I calculate this right or was I supposed to put tan 30 * 5 = 2.886751346 0r have I got this completely totally wrong?
That value is way off.
Before doing anything with your calculator, write down the equation that I suggested. Then solve for the unknown, and then use your calculator. (Make sure it is in degree mode.)
  • · Replies 25 ·
