Calculating momentum before and after a collision
by sdoyle1
Tags: collision, momentum
sdoyle1
sdoyle1 is offline
#1
Jul18-11, 11:13 AM
P: 23
A 1200 kg car traveling north at 14 m/s is rear-ended by a 2000 kg truck traveling at 25 m/s.
a) What is the total momentum before and after the collision?
b)If the car and truck lock bumpers and stick together, what is their speed immediately after the collision?
c) If the care and truck do not lock bumpers and the velocity of the car after the collision is 5 m/s, what is the speed of the truck after the collision?
2. Relevant equations
3. The attempt at a solution
I'm stuck on the concepts and my teachers hasn't gone into detail in class yet. If someone can explain the concepts then I can probably figure out the math.
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
thepatient
thepatient is offline
#2
Jul18-11, 11:23 AM
P: 140
Momentum is a vector quantity. In this case, you only have one component to worry about.
Formula for momentum P = mv
Also, momentum is conserved in collisions so the net initial momentum of the system is equal to the net final momentum.
sdoyle1
sdoyle1 is offline
#3
Jul18-11, 11:36 AM
P: 23
so would part a) just be a sum of both momentums? Or would I add the masses to get a total mass and multiply it by the total velocity (for both the truck and the car)?
cupid.callin
cupid.callin is offline
#4
Jul18-11, 11:40 AM
P: 1,135
Momentum of a particle is defined as the product of the mass and velocity of an object.
The law you will have to use here is the "Law of Conservation of Momentum."
It says that for a system, if net external force acting on it is 0, total momentum will remain constant.
Newton's second law (in original form) is: [itex]F = - \frac{dp}{dt}[/itex]
If p is constant, F=0.
cupid.callin
#5
Jul18-11, 11:41 AM
P: 1,135
Quote Quote by sdoyle1 View Post
yes it will be sum of momenta of both truck and car
sdoyle1
sdoyle1 is offline
#6
Jul18-11, 12:38 PM
P: 23
Ok, I have figured out part a. How would it change if the bumpers stick together? Would the mass be the 3200 kg? How about the velocity? Would it just be the total momentum divided by the total weight?
cupid.callin
#7
Jul18-11, 12:42 PM
P: 1,135
this is how collision will work:
truck is moving at higher speed than car. they collide, speed of truck dec. and that of car inc. and at some moment their speeed become equal.
then after that, car's speed inc. and that of truck dec and car starts moving faster than truck
so if they are locked together they will now have same speed and mass as sum of both car and truck
Register to reply
Related Discussions
Calculating X componet of Velocity in collision Introductory Physics Homework 3
Calculating Speed in Elastic collision Introductory Physics Homework 7
Calculating Spherical Collision Outcomes General Physics 3
Angular momentum and Linear momentum elastic collision Introductory Physics Homework 6
Calculating collision: finite elements General Physics 6
