Evaporarive cooling. How to calculate the cooling of the air?
  • Context: Undergrad
  • Thread starter Thread starter hacillunation
    Air Cooling
This discussion focuses on calculating the cooling effect of evaporative coolers in a controlled environment. The scenario involves a box containing 3 cubic meters of air at 10% humidity, with room temperature water (27°C) being sprayed as the air is blown out by a fan. Participants explore the expected temperature drop and methods to control humidity levels, including achieving 100% humidity versus 40%. The conversation references concepts such as wet bulb temperature and dew point, indicating their relevance in understanding evaporative cooling efficiency.
  • Understanding of evaporative cooling principles
  • Knowledge of wet bulb and dew point temperatures
  • Familiarity with humidity measurement techniques
  • Basic thermodynamics related to air and water interactions
  • Research the calculations for evaporative cooling efficiency
  • Learn about humidity control techniques in HVAC systems
  • Explore the impact of water temperature on cooling performance
  • Investigate the use of psychrometric charts for air properties
Engineers, HVAC professionals, and anyone interested in optimizing evaporative cooling systems for residential or industrial applications.
hacillunation
Hey,
So I'm trying to figure out how effective evaporative coolers are...
Lets say, I have a box with 3 cubic meters of air with a humidity of a 10%. I blow it out with a fan and spary with water as it leaves the fan.
The water is room temp (which is let's say 27 C).
What temperature difference should I expect?
Is there a way to control the amount of humidity by spraying more or less water? (How can I reach 100% humidity versus 40%)?
Thank you very much!
P.S I read wikipedia about Wet bulb, and Dew point... That didn't really helped me out...
Science news on Phys.org
See Treybel, Mass Transfer Operations
  • · Replies 32 ·
  • · Replies 21 ·
