| New Reply |
How to find the maximum rpm of the solid shaft that has a ring mounted on it? |
Share Thread | Thread Tools |
| Jul27-11, 02:21 AM | #1 |
Hello,
I have to find the maximum rpm of the shaft that has ring mounted on the shaft with interference fit of 0.002". I want to know at what rpm the ring will come loose from the shaft? and If I run the shaft at 7000rpm at 400 degree Celsius, is the interference fit of 002" enough for the ring to hold on to the shaft? How can I find out if it is adequate or not? Any suggestions will be appreciated. |
| Jul27-11, 08:26 AM | #2 |
Angular velocity will have no bearing on whether the collar will stay on the shaft. Differential thermal expansion could play a part though, if the two parts are made of different materials.
| New Reply |
| Thread Tools | |
Similar Threads for: How to find the maximum rpm of the solid shaft that has a ring mounted on it?
| Replacing a hollow shaft with a solid shaft | Engineering, Comp Sci, & Technology Homework | 3 | ||
| solid mechanics-how do i find the maximum momentum in this question? | Introductory Physics Homework | 0 | ||
| Stress in a ring that is mounted on a solid shaft | Mechanical Engineering | 16 | ||
| Stress due to rotation in a ring mounted on a shaft | Classical Physics | 4 | ||
| Percentage saving in weight of Hollow Shaft vs Solid Shaft | Engineering, Comp Sci, & Technology Homework | 24 | ||
