How Are Quantum Numbers Assigned to the Last Electron in an Aluminum Atom?
The four quantum numbers for the last electron in an aluminum (Al) atom are 3 (primary quantum number), 1 (secondary/azimuthal quantum number), -1 (magnetic quantum number), and +1/2 (spin quantum number). The primary quantum number indicates the energy level, which is 3 for Al. The secondary/azimuthal quantum number is derived using the formula n-1, resulting in a value of 1, indicating a p orbital. The magnetic quantum number, which defines the orientation of the orbital, is -1, corresponding to a specific p orbital orientation.
  • Understanding of quantum mechanics principles
  • Familiarity with electron configuration
  • Knowledge of quantum number definitions
  • Ability to interpret energy level diagrams
  • Study the rules for determining quantum numbers for various elements
  • Learn about electron configurations for transition metals
  • Explore the significance of quantum numbers in chemical bonding
  • Research energy level diagrams and their applications in quantum chemistry
Chemistry students, educators, and professionals in the field of quantum chemistry who seek to deepen their understanding of electron configurations and quantum numbers.
vg19
Hi,
What are the 4 quantum numbers for the last electron in the Al atom? I know how to get the primary quantum number and the spin quantum nmber, but I do not now how to get the secondary/azmuthal quantum number, and the magnetic quantum number.
The book gives the secondary/azmuthal quantum number as 1 "p", and the magnetic quantum number as -1
How do I get this values?
vg19 said:
Hi,
what shell is the last one in?
n = 3
what kindof shell
L = 1 (p shell)
what is the ml
since -L <= ml <= +L
and the negative one being the first subshell (px) and the positive one being the last subshell(pz)
and what is Ms?
Ms = +/- 1/2
where the positives are the first ones in and the negatives and the second ones in each of the subshells
draw anaenergy level diagram if you have a problem with this
The four quantum numbers for the last electron in an Al atom are: 3 (primary quantum number), 1 (secondary/azimuthal quantum number), -1 (magnetic quantum number), and +1/2 (spin quantum number). These numbers can be obtained by applying the rules and principles of quantum mechanics and electron configuration.
To find the secondary/azimuthal quantum number, you can use the formula n-1, where n is the primary quantum number. In the case of Al, the primary quantum number is 3, so the secondary/azimuthal quantum number would be 2 (3-1=2). The secondary/azimuthal quantum number represents the shape of the electron's orbital, and in this case, it is a p orbital.
The magnetic quantum number, represented by the letter m, determines the orientation of the electron's orbital in space. It can have values ranging from -l to +l, where l is the secondary/azimuthal quantum number. In the case of Al, l=2, so the possible values for m would be -2, -1, 0, 1, and 2. The book gave the value of -1, which would correspond to a p orbital with a specific orientation in space.
I hope this helps in understanding how to obtain the values for the secondary/azimuthal and magnetic quantum numbers. Remember, these numbers are determined by the electron's energy level and the rules of quantum mechanics, so they can vary for different elements.
  • · Replies 0 ·
