Grounding vs Earthing: What's the Difference?
The discussion revolves around the concepts of grounding and earthing in electrical circuits, exploring their definitions, applications, and differences. Participants examine the terminology used in American and British English and the implications of these terms in practical scenarios.
  • Some participants propose that "grounding" and "earthing" refer to the same process but are distinguished by regional terminology, with grounding being the American term and earthing the British term.
  • Others argue that grounding does not necessarily require a physical connection to the Earth, as it can involve connecting to any object that serves as an effective drain of charge.
  • A participant notes that the term "earth ground" is specifically used in American English to indicate a connection to the Earth.
  • Another participant challenges the initial premise by stating that a circuit can function with just a complete path for current, questioning the necessity of grounding or earthing in all cases.
  • This participant also highlights practical issues in systems like vehicles, where the body can serve as a return path, raising concerns about potential problems due to corrosion affecting circuit performance.
Participants express differing views on the necessity and definitions of grounding and earthing, indicating that multiple competing perspectives remain unresolved.
Some assumptions about the definitions of grounding and earthing may vary based on regional usage, and the discussion does not resolve the implications of these terms in all contexts.
BSEE
Every circuits needs to be grounded in order for it to work, but when do we need to take into consideration on earthing it, and what is the difference?
"Grounding" is the American English term and "Earthing" is the British English term for the same process: connecting parts of a circuit to an object that acts like an effective infinite drain of charge for the purposes of the given circuit. Note that circuits do not always have to be connected to the physical Earth to be considered grounded, just an object that serves the same purpose.
chrisbarid is correct. To add one thing, the term "earth ground" is often used in American English to specify a ground that IS a connection to the earth.
I think you are using the wrong term here. A circuit will work perfectly as long as there is a complete path for the current. This is often achieved with just two wires. Which one would you call the 'ground' then? Many systems (vehicles, for instance) use the body as a return path and this can save money for the starter circuit, in particular, as you only need one long thick cable, as the battery negative is usually strapped to the body by a short, thick lead. This is a constant source of problems in old bangers where RUST creeps in and adds nasty series resistance into the circuit so the starter won't turn.
  • · Replies 21 ·
