Biot-Savart law and Poisson's equation
The discussion revolves around the Biot-Savart law and its derivation from Poisson's equation, particularly focusing on the implications of singularities in the equations when applied to finite-radius conductors. Participants explore the behavior of the vector potential and magnetic fields in different scenarios, including infinite and finite wires.
  • One participant questions the singularity in the Biot-Savart law when evaluating the vector potential at the point of integration, suggesting that it leads to an infinite field inside a conductor.
  • Another participant argues that the singularity is not problematic due to the volume element in the integral, which behaves differently near the singularity.
  • A participant raises a concern about the disappearance of certain differential elements in spherical coordinates and questions the validity of the integration method used.
  • There is a discussion about the implications of the infinite vector potential in the context of Dirac sources and how this relates to the fields inside finite conductors.
  • One participant emphasizes the focus on the magnetic field and vector potential rather than the electric field, indicating a specific interest in the magnetic aspects of the problem.
Participants express differing views on the implications of singularities in the equations and the behavior of fields inside conductors. There is no consensus on whether the infinite vector potential leads to infinite fields inside finite conductors, and the discussion remains unresolved regarding the interpretation of these mathematical results.
Participants note potential limitations in the assumptions made regarding the nature of the current and the geometry of the conductors, as well as the mathematical treatment of singularities in the integrals.
Mbert
Dear colleagues,
I have questions regarding Biot-Savart law. From [1], it is shown that the equation (Biot-Savart) is derived from the solution to Poisson's equation (assuming here div A=0)
\begin{equation}
\vec{\nabla}^2 \vec{A} = -\mu \vec{J}
\end{equation}
which is
\begin{equation}
\vec{A}(\vec{r}) =\frac{\mu}{4\pi}\int_V{\frac{\vec{J}{\rm d}^3r'}{\left|\vec{r}-\vec{r'}\right|}}
\end{equation}
where $\vec{r}$ is the position where $\vec{A}$ is evaluated and $\vec{r'}$ is the position where the integral is evaluated.
The first thing that troubles me is the singularity $\left|\vec{r}-\vec{r'}\right|$ when we evaluate the field at the point of integration. For a wire of finite radius, this means that the $\vec{A}$ field inside the conductor is infinite (or am I missing something?). If so, why in books on electromagnetics do we usually replace the conductor by an equivalent filamentary current $I=\vec{J}\cdot{\rm d}\vec{s}$? The field calculated inside the conductor will be different. This can be seen from the solution for the $\vec{B}$ field by using Ampere's equation (for the infinitely-long finite-radius wire)
\begin{equation}
B_{\theta}=\frac{\mu I}{2 \pi \rho}
\end{equation}outside the wire
\begin{equation}
B_{\theta}=\frac{\mu I \rho}{2 \pi R_{wire}^2}
\end{equation} inside the wire
where $R_{wire}$ is the cross-section radius and $(\rho,\theta,z)$ are the cylindrical coordinates. This means essentially that the field at $\rho=0$ is zero and that it is proportional to $\rho$ inside the conductor and inversely proportional to $\rho$ on the outside. How can we get this from the solution to Poisson's equation for a finite-radius wire?
The other thing that troubles me with the solution to Poisson's equation (second equation) is the value of the integrand when $\vec{r}=\vec{r'}$, but outside the wire (thus where J=0). This means we get a 0/0 integrand for each $\vec{r}$ outside the wire, which numerically gives NaN for the whole integral. Is this a problem analytically? because this contribution might (should) be 0, probably by using L'Hopital's rule (I guess).
M.
[1] Smythe,W.R., "Static and dynamic electricity", McGraw-Hill, 1968.
M, I know the Poisson integral looks singular, but it is not. What you're forgetting about is the volume element. To see the behavior near r = r', write the integrand near that point in terms of a spherical coordinate, R = |r - r'|. Then d3r = 4π R2 dR, and the integral is like ∫ 4π J(0) R dR, which is nonsingular. The factor in the numerator that comes from the volume element goes to zero faster than the denominator does.
How did the [itex]{\rm d}\theta[/itex] and [itex]{\rm d}\phi[/itex] disappear in spherical coordinates? Isn't that equivalent of considering an infinitesimal rectangular prism [itex]xy{\rm d}z[/itex] (which would also be an infinitesimal volume, but not infinitesimal in all three dimensions)?
M.
In the immediate neighborhood of R = 0, the integrand is spherically symmetric and you can integrate at once over solid angle, producing the factor of 4π. In other words, ∫∫∫ ... d3r = ∫∫∫ ... R2 dR d2Ω = ∫ ... 4π R2 dR
As posted previously in the forums here:
https://www.physicsforums.com/showthread.php?t=119419"
the field of an infinite wire at r=0 is infinity. In your case, are saying that this field should be zero?
From Green's function, it is normal to get infinite vector potential, since we assumed Dirac sources. So the filamentary current case is ok with me. However, what happens inside with a finite conductor (e.g. a cylindrical conductor)? Wouldn't that mean we get infinity everywhere inside? Or this is perhaps where I mix things up.
thanks
M.
According to [itex]\vec{j}=\sigma \vec{E}[/itex] you get a finite electric field inside a finite conductor.
The solution of this standard magnetostatics problem, using the above (approximate, i.e., non-relativistic form of) Ohm's Law, for an infinite wire is a constant electric field along the wire.
I'm interested in the magnetic field B, not the electric field E. That's why I'm interested in the vector potential A, found from the solution of Poisson's equation.
M.
  • · Replies 21 ·
  • · Replies 0 ·
