Finding Molecule angles with vectors
  • Context: Undergrad
  • Thread starter Thread starter relativitydude
    Angles Molecule Vectors
The discussion revolves around determining the angles formed by electron pairs in a molecule, specifically focusing on configurations with three and four unbonded electron pairs. The scope includes theoretical reasoning and mathematical approaches to understanding molecular geometry.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant suggests that with three unbonded electron pairs, the angles can be calculated as 360º/3 = 120º, but questions how the angle becomes 109.5º with four unbonded pairs.
  • The same participant proposes using vector representation of the electron pairs and suggests that if they repel each other, the sum of the vectors should equal zero.
  • Another participant indicates that the electron pairs will form a tetrahedron and mentions that the angles can be found using trigonometry, offering to provide more details later.
  • A third participant references a mathematical resource for calculating the angles in a tetrahedron, specifically pointing to an angle related to the formula for tetrahedral geometry.
Participants do not reach a consensus on the method for calculating the angles, with differing approaches and some uncertainty about the calculations involved.
The discussion includes assumptions about the geometric arrangement of electron pairs and relies on trigonometric principles without fully resolving the mathematical steps involved in deriving the angles.
Readers interested in molecular geometry, chemistry, and mathematical modeling of physical systems may find this discussion relevant.
relativitydude
I posted this in the chemistry section, but I was recommended up here. We have a molecule with three unbonded electon pairs, so they will repel each other as much as possible. That's easy, it's 360º/3 = 120º
However, when we have four unbonded electron pairs the angle is 109.5º How?
I figured there are four vectors:
Vector A: (X1)i + (y1)j + (z1)k
Vector B: (X2)i + (y2)j + (z2)k
Vector C: (X3)i + (y3)j + (z3)k
Vector D: (X4)i + (y4)j + (z4)k
And if they repelled each other, it would simply be A + B + C + D = 0
I am figuring setting up this further by dotting the vectors and dividing by the norm to get an algebraic quantity representing the angle. The sum of the angles around XY would be 360º, XZ would be 360º, YZ would be 360º
Then squaring those individual XY, XZ, and YZ and taking the root of it to get 109.5º
Dare no one help?
The electron pairs will form a tetrahedron. Knowing that, you can find the angles using simple trigonometry. I'm in a bit of a hurry right now, but I can post details later if you want. :smile:
  • · Replies 17 ·
