Estimate Sun's Rotation Period as a Neutron Star
The problem involves estimating the rotation period of the Sun if it were to collapse into a neutron star, focusing on angular momentum conservation principles. The original poster provides the Sun's radius and rotation period, while the neutron star's radius is specified.
  • Participants discuss using conservation of angular momentum to relate the initial and final states of the Sun's rotation. There are attempts to clarify the meaning of the period given in days and to ensure proper unit conversions are applied.
Some participants have offered guidance on how to approach the problem using angular momentum equations. However, there are indications of confusion regarding the time unit for the period, and the original poster expresses uncertainty about their calculations.
There is a mention of potential conversion errors related to the period expressed in days, which may affect the calculations. The problem constraints include the assumption of no mass loss during the collapse.
wildrjetta
Could someone help me start this problem. My mind it in the angular momentum mode and I am having trouble seeing where to start on this one. :confused:
The sun's radius is 6.96E8m and it rotates with a period of 25.3d. Estimate the new period of rotation of the sun if it collapses with no loss of mass to become a neutron star of radius 5.5km. Give the result in seconds.
Thank you very much!
With the given radius you can find [tex]I_{initial}[/tex] and [tex]I_{final}[/tex]. With the given period, find out [tex]\omega_{initial}[/tex]. Then you use conservation of angular momentum to achieve your answer.
as such...(you don't need the moments of inertia exactly because it maintains a spherical shape and same mass so those factor out)
[tex](r_i)^2 \omega_i = (r_f)^2 \omega_f[/tex]
[tex]\omega_f = \frac{(r_i)^2 \omega_i}{(r_f)^2}[/tex]
[tex]T_{new} = \frac{2 \pi}{\omega_f}[/tex]
follow complete done
I calculated two different answers, both of which were to my dismay incorrect...but I am thinking that a conversion error might be the culprit. I am having trouble understanding what "a period of 25.3d" is -- as in, what does "d" stand for...should it be a time unit?
in a period d=days
THANK YOU THANK YOU THANK YOU! to everyone involved in helping with this problem! :biggrin:
9K
  • · Replies 0 ·
