Solving the Unknown in PDE: Finding u_B!
  • Context: Graduate
  • Thread starter Thread starter hermano
    Pde
The discussion focuses on solving a partial differential equation (PDE) related to fluid flow between porous and impermeable materials, specifically using slip-flow boundary conditions as outlined by Beavers and Joseph in 1967. The main challenge is to express the slip velocity, u_{B}, in terms of other variables to eliminate it from the equation for fluid velocity, u. The governing equation is derived from Poiseuille motion, and boundary conditions are provided to facilitate the solution. The proposed solution includes an ordinary differential equation that incorporates u_{B} to simplify the overall problem.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with fluid dynamics concepts, specifically Poiseuille flow
  • Knowledge of boundary conditions in fluid mechanics
  • Experience with mathematical modeling and differential equations
  • Research the Beavers and Joseph slip-flow boundary conditions in detail
  • Study methods for eliminating variables in PDE solutions
  • Learn about ordinary differential equations and their applications in fluid dynamics
  • Explore numerical methods for solving PDEs in porous media
Researchers, engineers, and students in fluid dynamics, particularly those working on problems involving porous materials and boundary layer theory.
hermano
unknown in PDE!
Hi,
I'm solving a problem which determines the flow between a porous material and an impermeable material, using the slip-flow boundary conditions as proposed by Beavers and Joseph in '67. I can solve the whole problem as stated below, which gives the velocity [itex]u[/itex] of the fluid in the x-direction over the gap height (y-direction). However, in this equation I still have one unknown namely [itex]u_{B}[/itex] which is the slip velocity. How can I write this [itex]u_{B}[/itex] in function of the other variables so that this unknown disappear in my equation of [itex]u[/itex] ? A hint can maybe be enough!
Poiseuille motion:
[itex]\frac{d^2u}{dy^2} = \frac{1}{\mu}\frac{dP}{dx}[/itex]
boundary conditions:
1. [itex]u = 0[/itex] at [itex]y = h[/itex]
2. [itex]\frac{du}{dy} = \frac{\alpha}{\sqrt{k}}u_{B}[/itex] at [itex]y = 0[/itex]
Solution of this PDE is:
[itex]u = \frac{1}{2\mu}\frac{dP}{dx}(y^2-h^2) + \frac{\alpha}{\sqrt{k}} u_{B} (y-h)[/itex]
As far as I see it, there is an equation ##u'=c\cdot u_B## which you can insert into your solution. This gives you an ordinary differential equation ##F(y,u,u')=0##.
  • · Replies 36 ·
