Does the Limit of a Polynomial Diverge as x Approaches Infinity?
  • Thread starter Thread starter quasar987
    Limit Polynomial
The limit of a polynomial diverges as x approaches infinity if the highest degree term dominates the behavior of the polynomial. For example, in the polynomial limx → ∞ (x3 + 2x2 + 3x + 4), the term x3 becomes infinitely large, leading to divergence. To formally demonstrate divergence, one can utilize the limit comparison test with a known divergent function, such as f(x) = x. This approach confirms that the polynomial's terms increase without bound as x increases, resulting in an infinite limit.
  • Understanding of polynomial functions and their limits
  • Familiarity with the concept of divergence in calculus
  • Knowledge of the limit comparison test
  • Basic algebraic manipulation skills
  • Study the properties of polynomial functions and their end behavior
  • Learn about the limit comparison test in detail
  • Explore examples of divergent and convergent functions
  • Investigate the formal definitions of limits and divergence in calculus
Students of calculus, mathematicians, and educators seeking to understand polynomial limits and divergence behavior.
quasar987
Question: How to show that the limit as x goes to infinity of a given polynomial diverge? We have
[tex]\lim_{x \rightarrow \infty} a_nx^n + a_{n-1}x^{n-1}+...+a_1x+a_0[/tex]
but cannot say the this limit is the sum of the limit of each term separetly because none of these limit exist. We cannot do this either
[tex]\lim_{x \rightarrow \infty} a_nx^n + a_{n-1}x^{n-1}+...+a_1x+a_0 = \lim_{x \rightarrow \infty} x^n(a_n + \frac{a_{n-1}}{x}+...+\frac{a_1}{x^{n-1}}+\frac{a_0}{x^n})[/tex]
and say the the limit is the product of the limit because one of the limit does not exist. So what then?
Thank you.
Let's take the case [tex]a_{n}>0[/tex]
What you CAN show, using your last equation, is that there exist [tex]N_{0}[/tex] so that [tex]\frac{a_{0}}{x^{n}}\geq{-\frac{a_{n}}{2n}}[/tex] whenever [tex]x\geq{N}_{0}[/tex]
Similarly, it exists [tex]N_{1}[/tex] so that:
[tex]\frac{a_{1}}{x^{n-1}}\geq{-\frac{a_{n}}{2n}}[/tex] whenever [tex]x\geq{N}_{1}[/tex]
And so on.
Setting N equal to the maximum of these [tex]N_{i}[/tex] values, yields the inequality:
[tex]x^{n}(a_{n}+++\frac{a_{0}}{x^{n}})\geq\frac{x^{n}a_{n}}{2}, x\geq{N}[/tex]
To show that the limit as x goes to infinity of a given polynomial diverges, we can use the definition of divergence. A polynomial will diverge if the absolute value of its terms increases without bound as x approaches infinity. In other words, the terms of the polynomial become infinitely large as x increases.
We can demonstrate this by looking at the highest degree term in the polynomial, which will dominate the behavior of the polynomial as x approaches infinity. For example, in the polynomial \lim_{x \rightarrow \infty} x^3 + 2x^2 + 3x + 4, the term x^3 will become infinitely large as x increases, causing the entire polynomial to diverge.
Additionally, we can use the limit comparison test to compare the given polynomial to a known divergent function, such as the function f(x) = x, as x approaches infinity. If the limit of the polynomial is equal to the limit of f(x), then the polynomial will also diverge.
In conclusion, to show that the limit of a polynomial diverges, we can use the definition of divergence and compare it to a known divergent function. By doing so, we can see that the terms of the polynomial become infinitely large as x approaches infinity, causing the limit to also become infinitely large and thus diverge.
  • · Replies 21 ·
