Mastering Partial Fractions for Solving Advanced Summation Problems
The discussion revolves around understanding the application of partial fractions in advanced summation problems. Participants are exploring how to manipulate summation expressions and the underlying principles involved in these transformations.
  • Participants discuss the transition between different forms of summation and the cancellation of terms. There is a focus on understanding the reasoning behind these manipulations and the broader techniques applicable to summation problems, including the potential use of mathematical induction.
The conversation is ongoing, with participants sharing insights and resources related to the topic. Some guidance has been offered regarding the use of partial fractions and the cancellation of terms in summations, but there is no explicit consensus on a singular approach or method.
Participants express a desire for resources to aid their understanding and question the general strategies for solving summation problems, indicating a need for further clarification on foundational concepts.
embassyhill
Obviously I don't need a solution because it's right there. What I need to understand is what happened after the third equation sign and more importantly, how would I learn to solve these kinds of problems on my own. I looked at Wikipedia and even though it was helpful, I still don't understand this specific exercise for example. I would be grateful if someone could point me at a resource on this topic.
So you're wondering how to go from:
[tex]\frac{1}{2}(\frac{1}{1}-\frac{1}{3}) + \frac{1}{2}(\frac{1}{3}-\frac{3}{5}) + ... + \frac{1}{2}(\frac{1}{2n-1}-\frac{1}{2n+1})[/tex]
to:
[tex]\frac{1}{2}(1-\frac{1}{2n+1})[/tex]
Factor a 1/2 out of all the terms and then add the stuff inside. Something interesting happens. For example:
(1/2)(a+b) + (1/2)(c+d) = (1/2)(a+b+c+d)
Ok so everything but 1/1 and -1/(2n+1) cancel each other out. Now I get this exercise but what about the bigger question? Are there any tricks to learn here (about the sigma) or is it just about using your knowledge of algebra?
It depends on the problem, but a lot of times you can use mathematical induction to prove summation results. There's an example of it on wiki:
http://en.wikipedia.org/wiki/Mathematical_induction
This assumes that you know what you're trying to prove ahead of time (like in the case of your example). However, if you want to know a general way of finding the sum of n terms, there's no standard way, as far as I know. The best you can usually do is some trick like the one I showed you, or see if you're looking at a geometric sum. Otherwise, memorize these:
http://en.wikipedia.org/wiki/Summation
Partial fractions:
[tex]\frac{1}{(2x-1)(2x+1)} = \frac{1/2}{2x-1} - \frac{1/2}{2x+1}[/tex]
  • · Replies 0 ·
