Sound Waves and Interference Problem - Check My Work?
The discussion focuses on a sound wave interference problem involving two loudspeakers with power outputs of 400 W and 100 W, respectively. The listener is positioned 20 m from the 100 W speaker and 40 m from the 400 W speaker. The intensity ratio of the two sounds at the listener's position is calculated to be 10. The highest frequencies for constructive interference are determined to be approximately 19,979.75 Hz and 19,996.9 Hz, while the frequencies for destructive interference are around 19,971.18 Hz and 19,988.33 Hz. The displacement amplitude from the 400 W speaker at a frequency of 5000 Hz is calculated to be 3.18 x 10-7 m.
  • Understanding of sound intensity and power calculations
  • Familiarity with wave interference concepts
  • Knowledge of the equations for sound wave displacement and frequency
  • Basic principles of acoustics and wave propagation
  • Study the derivation of sound intensity formulas, specifically I = Ps/(4πr2)
  • Learn about constructive and destructive interference in sound waves
  • Explore the relationship between frequency, wavelength, and wave speed in acoustics
  • Investigate the impact of distance on sound intensity and amplitude
Students studying physics, particularly those focusing on acoustics and wave phenomena, as well as educators seeking to enhance their understanding of sound wave interference principles.
Malavin
Okay, I have this problem worked out, but I have no clue if my answers are right. Could someone please check my work and give me some confidence or show me where I may have messed up.
Two loudspeakers, one of them generates sound with 400 W power the other with 100 W. The sound is generated isotropically (the same in all directions) from each loudspeaker. A listener is seated 20m from the 100 W loudspeaker and 40 m from the other loudspeaker. A signal generator drives the two speakers in phase with the same frequency. The frequency is swept through the audible range from 20-20,000 Hz.
a) What is the ratio of the intensities of the two sounds (I(for 400W)/I(for 100W)) at the listener's position?
b) What are the two highest frequencies at which the listener will hear a maximum signal because of constructive interference?
c) What are the two highest frequencies at which the listener will hear a minimum signal because of destructive interference?
d) Assuming a single frequency of sound (f= 5000Hz) from the 400 W loudspeaker. What is the displacement amplitude of the sound waves that arrives at the listener's position from the 400 W loudspeaker only?
I = Ps/(4πr2)
I = 0.5ρvω2sm2
ΔL/λ = 0, 1, 2... (fully constructive interference)
ΔL/λ = 0.5, 1.5, 2.5... (fully destructive interference)
v = λf
vair = 343 m/s
ρair = 1.21 kg/m3
a) I1 = Ps/(4πr2) = 400/(4π402) = 1.99*10-2 W/m2
I2 = 100/(4π202) = 1.99*10-3 W/m2
I1/I2 = 10
b) ΔL/λ = ΔL/(v/f) = fΔL/v = f(40-20)/343 = 0, 1, 2...
f = (0, 1, 2...)*17.15 Hz
fmaxf = 20,000 Hz
Looking for two highest frequencies: (n)17.15 Hz ≤ 20,000 Hz
n ≤ 1166.18
nmax = 1165, 1166
fmax = 19,979.75 Hz, 19,996.9 Hz
c)f = (0.5, 1.5, 2.5...)*17.15 Hz
n ≤ 1166.18
nmax = 1164.5, 1165.5
fmax = 19,971.18 Hz, 19,988.33 Hz
d)ω = 2πf = 2π(5000) = 10000π
I = 0.5ρvω2sm2
sm = √(2I/(ρvω2))
sm = 3.18*10-7 m
For (a), try recalculating I2. I get a different number.
(b), (c) and (d) look good.
  • · Replies 19 ·
