Solving the Combustion of Octane
  • Thread starter Thread starter tanya234
    Combustion
The combustion of 1 litre of octane (C8H18) requires approximately 8.6 cubic meters of air, which consists of 78% nitrogen (N2) and 22% oxygen (O2) by volume. The stoichiometric equation for the combustion is C8H18 + 25/2 O2 → 8 CO2 + 9 H2O. Given that 1 mole of oxygen gas equals 24.5 litres, the calculation involves determining the fuel-to-air ratio (FAR) using the molecular weights of octane and air. The final result indicates that 10.4 kg of air is necessary for complete combustion of 0.7 kg of octane.
  • Chemical equations and stoichiometry
  • Understanding of combustion reactions
  • Knowledge of gas laws and molar volumes
  • Basic calculations involving density and mass
  • Study the principles of stoichiometry in chemical reactions
  • Learn about the ideal gas law and its applications
  • Explore the concept of fuel-to-air ratios in combustion
  • Investigate the environmental impact of octane combustion products
Chemistry students, chemical engineers, environmental scientists, and anyone involved in fuel combustion analysis.
tanya234
Hello, how would i solve the following?:
"How many litres of air (78% N2, 22% O2 by volume) are needed for the combustion of 1 litre of octane, C8H18, a typical gasoline component, of density 0.70g/mL?"
Note - 1 mole of oxygen gas is equal to 24.5 litres.
I have done the chemical equation of the combustion of octane which is C8H18 + 25/2O2 ---> 8CO2 + 9H20 but I am unsure about what to do next.
Thank you :smile:
Chemistry news on Phys.org
Thank you :smile:
Assuming a complete combustion:
[tex]C_8 H_{18} + a(O_2+3.714N_2)\rightarrow b CO_2 + c H_2O[/tex]
Conservation of atoms:
b=8, c=9, a=25/2 (you were right)
So that, the Fuel to Air ratio at stochiometric conditions is: W=molecular weight, N=moles, m=mass, f=fuel, a=air:
[tex]FAR_s=\frac{m_f}{m_a}=\frac{W_f N_f}{W_a N_a}=\frac{W_f}{4.714W_a a}=\frac{114 g/mol}{4.714\cdot 28.9 \cdot 25/2}=\frac{0.0669 g_{fuel}}{g_{air}}[/tex]
1 litre of octane is 0.7 Kg. So that you will need 0.7/0.066=10.4 Kg of air, which at normal conditions has a density of 0.0012 Kg per litre, therefore 8.6 cubic meters of air will be needed.
11K
  • · Replies 33 ·
9K
21K
9K
