How Is the Boundary Layer Analyzed as Incompressible in Viscous Flow?
The discussion focuses on analyzing the boundary layer of a parallel air flow along a semi-infinite flat plate, specifically under the condition of incompressibility. The key criterion established is that the flow can be treated as incompressible if the Mach number squared, M²₍₍∞₎, is significantly greater than 4. The formula for M²₍₍∞₎ is defined as M²₍₍∞₎ = U² / (γRT), where U represents the flow speed, γ is the specific heat ratio, R is the gas constant, and T is the temperature. This analysis is crucial for understanding viscous flow behavior in fluid dynamics.
  • Understanding of fluid dynamics principles
  • Familiarity with the concept of the Mach number
  • Knowledge of boundary layer theory
  • Basic thermodynamics, including the ideal gas law
  • Study the derivation and implications of the Mach number in fluid dynamics
  • Explore boundary layer theory and its applications in engineering
  • Investigate the conditions for incompressible flow in various fluid scenarios
  • Learn about the Navier-Stokes equations and their role in viscous flow analysis
Students and professionals in fluid dynamics, mechanical engineers, and researchers focusing on viscous flow analysis and boundary layer behavior in aerodynamics.
Stonescar
Hello,
I'm looking at this problem which states:
"A parallel air flow along a semi infinite flat plate has undisturbed parameters as follows: "
Then they list the speed, temprature, viscousity and pressure.
"Demonstrate that the boundary layer can treated by means of incompressible analysis. "
The solution says:
Incompressible if M[itex]^{2}_{\infty}[/itex]>>4
Where M[itex]^{2}_{\infty}[/itex]=[itex]\frac{U^{2}}{\gamma R T}[/itex]
I'm just wondering what formula this is? I've never seen it before.
What is M ?
M is the Mach Number.
  • · Replies 16 ·
17K
  • · Replies 48 ·
9K
