What is the meaning of proportional and how is it used in different contexts?
  • Thread starter Thread starter Instinctlol
    Mean Proportional
The discussion revolves around the concept of proportionality, exploring its meaning and application in various contexts. Participants seek clarification on how proportional relationships are defined and represented mathematically.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the definition of proportionality, with examples involving population growth of ants and their food consumption. Questions arise regarding the correct interpretation of proportional relationships and the common misconceptions associated with the term.
Some participants provide explanations and examples to clarify the concept of proportionality, including the role of a constant of proportionality. There is acknowledgment of errors in previous posts, and the discussion appears to be ongoing with multiple interpretations being explored.
Participants note the importance of distinguishing between proportional relationships and other types of dependencies, highlighting common misunderstandings among students regarding the term "proportional."
Instinctlol
I hear teachers say something is proportional to something else. What does "proportional " mean? Can someone explain to me with some examples? Thanks !
Proportional means that something changes with respect to something else. For instance, ants eat food, and the more food they eat the more they can reproduce. Thus, the population growth of the ants is proportional to the amount of food. You could also say that the population growth is "inversely proportional" to the amount of ant killer in their environment.
This is usually facilitated by use of a constant of proportionality, sometimes called k. When something is proportional to something else, it does not mean the values are equal, just that they change with respect to each other. The constant of proportionality serves as a multiplier.
If T is the population growth of ants, and P is the amount of food in their environment. You could say that:
[itex]T∝P[/itex]
More specifically, that means that the values likely only differ by a constant, so you can say:
[itex]T=kP[/itex]
An example of inversely proportional would be something like:
[itex]T = k\frac{1}{M}[/itex] where M is ant killer, poison, or whatever I said before.
Edited: Mistake corrected.
If T population growth of ants, and P is the amount of poison in their environment. You could say that:
[itex]T∝P[/itex]
[itex]T=kP[/itex]
Great explanation, thank you!
I just realized that I made an error. This line:
"If T population growth of ants, and P is the amount of poison in their environment. You could say that:"
..should read "food" instead of poison! I hope you caught that one. I will edit my original post to be accurate.
Note that proportional means the two variables are related by a constant factor. If Y is proportional to X, that always means Y=kX for some constant k.
A common misuse of the term by students is to take proportional to mean depends on. For example, if Y=X2, they would say Y is proportional to X, which is not correct. If X varies, Y does too, but Y doesn't vary in the right way to say it's proportional to X.
Schrödinger slip?
^ freudian slip. Stop mixing up your physicists and psychologists... unless your comment was in irony and I missed it? =P
As for an easy way to think about proportionality: as x increases, so does y AT A CONSTANT RATE
So time taken for a falling object to hit the floor is proportional to the square root of the height at which it was released.
Force is proportional to the product of mass and velocity.
To make a proportion sign into an equals sign you need to introduce 'k' as a constant.
Yes, you missed it.
  • · Replies 55 ·
