Is Integration in d-Dimension Well Defined for 1<|q|<∞
  • Context: Graduate
  • Thread starter Thread starter kassem84
    Integration
The discussion centers on the mathematical definition of integration in d-dimensions, particularly for the case where 1 < |q| < ∞. It is established that the integral \int_{|q|>1} d^{d}q f(q^2) is well-defined, while the massless tadpole integrals \int_{|q|>1} d^{d}q (q^2)^{β} do not equal zero for β = 1, 2, etc. The arguments for dimensional analysis and convergence do not hold in this context, leading to the conclusion that the integral cannot be consistently set to zero.
  • Understanding of dimensional regularization in quantum field theory.
  • Familiarity with the concept of integrals in d-dimensional space.
  • Knowledge of the properties of massless tadpole integrals.
  • Basic grasp of dimensional analysis and convergence in integrals.
  • Research the implications of dimensional regularization on quantum field theories.
  • Study the mathematical properties of integrals in non-integer dimensions.
  • Explore the behavior of massless tadpole integrals in various dimensional contexts.
  • Learn about convergence techniques for integrals in quantum field theory.
Physicists, mathematicians, and researchers involved in quantum field theory, particularly those focusing on dimensional regularization and integral convergence issues.
kassem84
Hello,
As you may know in the context of dimensional regularization, integration is performed in d-dimension where d can take non-integer values. For example:
[itex]\int d^{d}q f(q^2)[/itex]=S[itex]_{D}[/itex][itex]\int_{0}^{∞}q^{q-1}f(q^2)dq[/itex]
My questions are:
1) Is the integration in d-dimension performed is well defined in the mathematical sense when integration is done for: 1<|q|<∞ rather than 0<q<∞:
[itex]\int_{|q|>1} d^{d}q f(q^2)[/itex]=S[itex]_{D}[/itex][itex]\int_{1}^{∞}q^{q-1}f(q^2)dq[/itex]
2)Are tadpole mass-less integrals still equal to zero in DR?
[itex]\int_{|q|>1} d^{d}q (q^2)^{β}[/itex]= 0 for β=1,2,...
Thanks in advance.
Best regards.
With regards to 1) I think that the integral should be fine. Just imagine
f(q2) = θ(q2-1)g(q2)
But as for 2) and the massless tadpoles, no, you can no longer consistently set them to zero.
Normally, for the integral over all q, you can argue for its vanishing in two ways:
a) Dimensional analysis: The only dimensional quantity is q, with [q]=1. So The integral has dimension d + 2β. Since you integrate out q, no dimensional quantities remain, so the only consistent result is that the integral must be 0.
b) The integral does not converge for any particular choice of d. But splitting the integral in half (or wherever) and choosing different d's for each half so that it converges in both UV and IR, then recombining the integral, the UV and IR poles cancel and the result is zero.
With your integral, both arguments don't work. For a), your "1" actually has the dimensions of mass (since otherwise |q|>1 would not make sense) and so the argument fails.
For b), you no longer have an IR limit, so there is no cancellation with the UV.
Hope that helps,
Simon
Thanks Simon for your answers.
  • · Replies 0 ·
  • · Replies 19 ·
