Problem finding a partial derivative
The discussion centers on calculating the second partial derivative of the function v = \frac{xy}{(x-y)} using the quotient rule. The user, Glenn, initially derived v_{xy} as \frac{2xy-4y^2}{(x-y)^3}, which was incorrect. The correct answer, as provided by Wolfram Alpha, is \frac{2xy}{(x-y)^3}. The error stemmed from neglecting the negative sign in the derivative of the inner function during the application of the quotient rule.
  • Understanding of partial derivatives
  • Familiarity with the quotient rule in calculus
  • Basic knowledge of algebraic manipulation
  • Experience using computational tools like Wolfram Alpha
  • Review the application of the quotient rule in calculus
  • Practice finding higher-order partial derivatives
  • Explore the use of Wolfram Alpha for verifying calculus problems
  • Study common mistakes in derivative calculations
Students studying calculus, particularly those focusing on multivariable functions and partial derivatives, as well as educators seeking to clarify common errors in derivative calculations.
chexmix
I am working on a homework problem involving partial derivatives. I've been checking my answers against what Wolfram Alpha spits out just for extra assurance. For the following problem
Find all the second partial derivatives: v = [itex]\frac{xy}{(x-y)}[/itex].
When I get to the point where I am deriving v[itex]_{xy}[/itex], Wolfram Alpha gives me
[itex]\frac{2xy}{(x-y)^3}[/itex]
but I get something different. If someone can tell me where I am going wrong here, I would be most grateful: I've stared at this for some time now. I suspect it is something very trivial. I am using the quotient rule.
2. The attempt at a solution
[itex]\frac{\partial}{\partial y}[/itex] [itex]\frac{y^2}{(x-y)^2}[/itex]
[itex]\frac{(x-y)^2 * 2y - y^2 * (2 (x-y))}{(x-y)^4}[/itex]
[itex]\frac{(x-y)((x-y)*2y - 2y^2)}{(x-y)^4}[/itex]
[itex]\frac{2xy-4y^2}{(x-y)^3}[/itex]
Thanks,
Glenn
You forgot the minus.
[itex]\frac{\partial}{\partial y}[/itex] [itex]\frac{-y^2}{(x-y)^2}[/itex]
And in your quotient rule, you forgot the derivative on the "inner" function, which is -1.
[itex]\frac{\partial(x-y)^{2}}{\partial y}=2(x-y)(-1)[/itex]
Ahh, I was even further off than I thought. Thanks so much. It makes sense now.
