New Reply
Fixed Point Problems
Share Thread Thread Tools
Oct10-11, 10:06 PM   #1
Find all real values x that are fixed by the function y=4-x^2
f(x)=4-x^2
2. Relevant equations
x=y
3. The attempt at a solution
x=4-x62
0=-x^2-x+4
0=-(x^2+x+(1/4))+(17/4)
This is where i get stuck.
I also have two other problems which iIdo not understand how to work with.
f(x)=7+sqrt(x-1)
f(x)=sqrt(10+3x) -4
The main problem keeping me from doing the the two above is not knowing what to do with the square root of the expression underneath. Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct11-11, 01:26 AM   #2
Remember that you want to isolate x. Focus on doing that. If you are completing the square, be sure you know that method.
Oct11-11, 07:16 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
A "fixed point" for a function f is a value of x such that f(x)= x.
1) [itex]4- x^2= x[/itex] gives [itex]x^2+ x- 4= 0[/itex].
Solve that by completing the square or using the quadratic formula.
2) [itex]7+ \sqrt{x- 1}= x[/itex] is the same as [itex]\sqrt{x- 1}= x- 7[/itex].
Square both sides to get [itex]x- 1= (x- 7)^2= x^2- 14x+ 49[/itex].
That is also a quadratic equation- but this time is easily factorable. Be sure to check your answers in the original equation. "Squaring both sides" of an equation can introduce spurious solutions.
3). [itex]\sqrt{10+ 3x}- 4= x[/itex] is the same as [itex]\sqrt{10+ 3x}= x+ 4[/itex]. Again, square both sides to get a quadratic equation. Be sure to check your answers in the original equation.
Oct11-11, 05:31 PM   #4
Quote by HallsofIvy View Post
So for the 1st problem would the answer be [itex](\sqrt{17}/2)-(1/2)[/itex] or [itex](-\sqrt{17}/2)-(1/2)[/itex] Thanks for all of your help by the way.
New Reply
Tags
fixed, points, precalculus, root, square
Thread Tools
Similar Threads for: Fixed Point Problems
Thread Forum Replies
fixed point iteration Engineering, Comp Sci, & Technology Homework 17
hyperbolic fixed point Calculus & Beyond Homework 0
Fixed Point Numbers Programming & Comp Sci 6
Fixed Point in Continuous Set Calculus & Beyond Homework 5
Fixed Point of a function Calculus 1
