Gravitation acceleration question
A uniform solid sphere with radius R generates gravitational acceleration a(g) on its surface, defined as a(g) = (4πGρ/3)R. To find the distances from the center of the sphere where gravitational acceleration equals a(g)/3, two cases are considered: outside the sphere (r > R) and inside the sphere (r < R). For the external distance r_1, the equation MG/r_{1}^2 = g/3 leads to r_1 = √(3R^2). For the internal distance r_2, the gravitational field is derived from the mass of the sphere, resulting in r_2 = (3/4)R.
  • Understanding of gravitational acceleration and Newton's law of gravitation
  • Familiarity with the concepts of uniform density and gravitational fields
  • Knowledge of basic algebra and equations involving variables
  • Concept of gravitational forces inside and outside a uniform sphere
  • Study the derivation of gravitational acceleration for different geometries
  • Learn about the implications of Gauss's law in gravitational fields
  • Explore the concept of gravitational potential energy in spherical bodies
  • Investigate the effects of varying density distributions on gravitational fields
Students of physics, astrophysicists, and anyone interested in gravitational theory and its applications in celestial mechanics.
jenavira
A uniform solid sphere with radius R produces a gravitational acceleration a(g) on its surface. At what two distances from the center of the sphere is the gravitational acceleration a(g)/3?
I know that gravitational acceleration = GM/r^2, and that on the surface of the sphere, a(g) = (4 pi G rho /3)R. Beyond that...I'm kinda stumped. (I managed to find an explanation of this somewhere, but it didn't really help. I get that you can replace (4 pi G rho/3) with a constant, but...)
You should realize or be able to figure out that
[tex]g(r) = g_0 \left(\frac {R}{r} \right)^2[/tex]
when r > R and
[tex]g(r) = g_0 \frac {r}{R}[/tex]
when r < R.
One of the position is going to be outside the sphere and the other is going to be inside.
For outside: One of the distance is going to be outside the sphere because the gravitationnal force, and therefor the gravitationnal field (=F/m) decreases continuously with the distance. So there must be a distance [itex]r_1 >R[/itex] somewhere where the field is g/3.
We know [itex]MG/R^2 = g[/itex], and we want to find [itex]r_1[/itex] such that [itex]MG/r_{1}^2 = g/3 = MG/3R^2[/itex]. Solve for [itex]r_1[/itex].
For inside: You have to know that a shell of uniform matter density produces no net gravitationnal field inside of it. With that in mind, you can regard a point a distance [itex]r_2[/itex] inside a uniform sphere as being inside a shell of thickness [itex]R-r_2[/itex] and at the surface of a sphere of radius [itex]r_2[/itex]. Therefor, only the matter of the sphere exerts a net gravitationnal force at [itex]r_2[/itex]. You must also know that a sphere of uniform density produces the exact same gravitationnal field at every distance at its surface (and beyond) as a point particle located at its center would. Work out a formula for the mass of the sphere. How does it relate to M? Solved for [itex]r_2[/itex] just like for outside.
  • · Replies 43 ·
  • · Replies 63 ·
