Convert MS Word documents into LaTeX
The discussion revolves around the conversion of MS Word documents, particularly those containing MathType equations, into LaTeX format and subsequently into PDF files. Participants seek guidance on the feasibility of this process, necessary software, and steps involved.
  • Homework-related
  • One participant questions the possibility of converting MS Word documents with MathType equations into LaTeX and requests guidance on software and procedures.
  • Another participant suggests a specific utility from the TeX User Group for conversion and recommends installing MiKTeX as a TeX system.
  • A third participant notes the need to convert MathType equations to LaTeX first, mentioning specific commands available in MathType for this purpose.
  • One participant proposes that creating PDF files directly from Word might be a simpler alternative to the conversion process.
Participants express varying opinions on the necessity and complexity of converting documents versus directly creating PDFs from Word. There is no consensus on the best approach or the necessity of conversion.
Participants do not fully explore the limitations of the conversion process, such as potential issues with formatting or compatibility of MathType equations in LaTeX.
jemma
I realize this is most likely an extremely basic question but I can't seem to find the answer...
I am wondering if it's possible to convert MS Word documents (with some MathType equations) into LaTeX (and then into pdf files)? I have never used LaTex before and would appreciate some basic guidance as to (a)is this possible, (b)what software I need to download and (c)what I actually need to do!
Try here: http://www.tug.org/utilities/texconv/pctotex.html
I don't have first hand experience of them, but the TeX User Group (TUG) is as good a place to start looking as any.
Obviously you need to install a TeX system on your PC. I would recommend http://miktex.org/ (which is free).
You will need to learn the basics of how to use LaTeX. There are plenty of tutorials on the web, of varying quality. Tutorials produced by universities for their students are usually good. Or read "The not so short introduction to LaTeX2e" (google the title, or look for a file called lshort.pdf).
You'll need to convert the MathType equations to LaTeX first. You can do that with the Toggle TeX command, but you'll get more consistent results by using the Convert Equations command. Both of these commands are on the MathType tab in Word. Look in MathType Help for instructions on using these commands. Post follow-up questions here if you'd like.
If you finally want to create pdf files, why don't you do that directly from word?
9K
  • · Replies 20 ·
