Flow rate measurement: Venturi vs Sharp edged circular orifice. Help
The discussion focuses on the comparison of flow rate measurement techniques using Venturi tubes and sharp-edged circular orifices. It establishes that the discharge coefficient (Cd) for Venturi tubes is typically around 0.98, significantly higher than the sharp-edged orifice, which has a Cd of approximately 0.60. The loss of head in Venturi tubes is primarily due to friction, and the discussion highlights the need for recalibration when using fluids with different viscosities or densities. Additionally, the advantages and disadvantages of each flow meter type are explored, emphasizing their practical applications.
  • Understanding of fluid dynamics principles
  • Familiarity with discharge coefficients (Cd)
  • Knowledge of head loss calculations in flow measurement
  • Awareness of ISO 5167 standards for flow measurement
  • Research the ISO 5167 standard for flow measurement accuracy
  • Study the effects of fluid viscosity on discharge coefficients
  • Explore advanced flow measurement techniques beyond Venturi and orifice meters
  • Investigate the impact of pressure tapping locations on head measurement
Engineers, fluid dynamics researchers, and professionals involved in industrial flow measurement who seek to understand the comparative performance of Venturi tubes and sharp-edged orifices.
davekardle
Flow rate measurement: Venturi vs Sharp edged circular orifice. Help! :)
Hello guys, I am having trouble answering these questions.
I know the the discharge coefficient for a venturi is always higher
than that of the sharp edge orifice. Can you guys help me out with the following questions ?
1. Think about the head profiles and the loss of head from inlet to outlet of the venturi tube in P1. Are any experimental values of Hn greater than the theoretical values (Hn)t? If so, can you suggest a reason? (Look at the pressure tappings in this region).
2. What is the head lost in the venturi and is this significant compared with the total theoretical head? How does this loss of head arise?
3. (a) Why is Cd quite close to 1 for the venturi, but significantly less than 1 for the sharp-edged orifice? Compare with values of Cd in the textbooks.
(b) Is Cd constant within the range of each experiment?
(c) Would the meter need recalibration if it were used with a fluid of different viscosity or density? (Does Cd depend on the fluid properties)?
4. Why is the jet narrower than the orifice?
5. What are the advantages and disadvantages in practice of venturis and orifice plates as flow meters? In what circumstances is each most often used?
2. The loss is caused by friction.
3a: In venturi the Cd equals to the actual value/ theoretical value. It is typical 0.98. WHEREAS for the Sharped edge orifice, the Cd = Cc x Cv . Cc is the coefficient of contraction ( typical 0.60).
3b. Yes
I am really clueless about these questions guys, help me out ;(
  • · Replies 45 ·
