Conservation of Momentum question
The problem involves the conservation of momentum in a system of five identical train cars. Initially, three cars are moving at 3.71 m/s, and a fourth car traveling at 6.74 m/s couples with them, resulting in a combined speed of 4.47 m/s. When this four-car train collides with a fifth car at rest, the final speed of the five-car train is calculated to be 3.57 m/s. The momentum conservation principle is applied through the equations m1v1 + m2v2 = m1v1' + m2v2', leading to the final results.
  • Understanding of momentum conservation principles
  • Familiarity with algebraic manipulation
  • Knowledge of basic physics concepts related to collisions
  • Ability to apply equations of motion in one dimension
  • Study advanced collision types, including elastic and inelastic collisions
  • Learn about momentum conservation in multi-body systems
  • Explore real-world applications of momentum conservation in transportation
  • Investigate the effects of mass and velocity on momentum in different scenarios
Students studying physics, educators teaching momentum concepts, and anyone interested in understanding collision dynamics in mechanics.
JANF0R
Three identical train cars, coupled together, are rolling east at 3.71 m/s. A fourth car traveling east at 6.74 m/s catches up with the three and couples to make a four-car train. A moment later, the train cars hit a fifth car that was at rest on the tracks, and it couples to make a five-car train. All 5 cars are identical. What is the speed of the five-car train?
m1v1+m2v2+... = m1v1'+m2v2'+...
Welcome to PF, Janfor.
I can't help much until you attempt the problem yourself (bad for your education and boring for me).
You have two collisions in this problem. You can deal with them one at a time. For a collision, you write
MOMENTUM BEFORE = MOMENTUM AFTER
Put in "mv" for each moving object, before and after.
Then put in the numbers for each m and v.
Hopefully there will only be one unknown so you can solve for it!
Bon chance.
you have the right equation, so just plug in the variables:
the momentum of the train initially is the total of all three cars plus the total of the fourth cart:
(3m)*(3.71)+(6.74m) = (4m)(V)
the reason that this is the equation is because momentum before the collision equals the momentum after the collision. Since the cars are identical, mass can be identified as a constant m. also, when the fourth train impacts the three trains, the velocity will change because the momentum is moving faster, meaning we need a new variabe, V
When solving algebraically for v, you'll find that the m's cancel and you get v=4.47
now given the new velocity of the train, do the same thing:
(4m)*(4.47) = (5m)(v)
there is no addition because there is only one thing moving before and after the collision, since car 5 is initially at rest and the cars combine afterwards
solve for v again and get v = 3.57m/s
12K
