How much embedded programming in control/signal processing?
The discussion revolves around the role of embedded programming in the fields of control and signal processing within electrical engineering. Participants explore the extent to which embedded systems, including microcontrollers, FPGAs, and real-time operating systems, are integrated into these areas of study and practice.
  • One participant expresses concern about the prevalence of embedded programming in control and signal processing, indicating a desire to minimize engagement with it.
  • Another participant asserts that control projects almost invariably involve some form of embedded programming, while signal processing may allow for more analog design work.
  • A question is raised regarding the specific types of embedded programming involved in control projects, including the implementation of control algorithms versus writing device drivers.
  • A participant shares their experience with embedded programming in control projects, noting the use of C or C++ and low-level real-time operating systems, along with specific examples of code developed for digital filters and PID controllers.
  • Concerns about the complexity of real-time operating systems and threading are addressed, with a suggestion that these challenges are part of the engineering process.
  • There is mention of the potential for using FPGAs in control design, although one participant notes limited experience with this approach, primarily using FPGAs for hardware interface support.
Participants do not reach a consensus on the necessity of embedded programming in control and signal processing, with differing views on the extent to which it is involved and the comfort level with these technologies.
Participants express varying degrees of familiarity and comfort with embedded systems, indicating that the discussion is influenced by personal experiences and preferences. There are also unresolved questions about the specific skills and knowledge required for different roles within these fields.
walk_w/o_aim
Hey there,
(I apologize if this is in the wrong section - please move it if it is)
I'm an EE undergrad, and I'm wondering how much embedded software/programming is involved in fields like control and signal processing. To be a bit more specific, by "embedded software," I'm referring to things such as programming microcontrollers/FPGAs, dealing with embedded/real-time OS, and writing device drivers.
I realize that embedded systems are so prevalent that it may be impossible to go into any area of EE without encountering them in some fashion, but I'd like to avoid dealing with them too frequently if at all possible. I can't really decide which among control, signal processing and analog electronics I find more interesting, while embedded systems has always scared me. Anyway, that's just an aside.
Thanks!
I do control and signal processing design work (mainly embedded programming!) so here is my experience on the subject:
I doubt you will find any control projects that don't use embedded programming in some form.
Signal processing is more hybrid as most designs will have analog and digital portions (with some being strictly analog). There is definatley more room to do analog design work in this field.
Hey Floid,
Thanks for replying. If you don't mind me asking a few other questions, what sort of embedded programming do you mostly do in your control projects? For instance, is the work mostly implementing control algorithms, or is it more along the lines of writing device drivers? How important, for example, is a knowledge of (RT)OS concepts and kernels?
Thanks again!
Usually I don't have to do the real low level device driver code, but I have had to do that before as well so that isn't a given.
Generally the controls projects are written in C or C++ and use some type of low level RTOS. The last one I did used Analog Devices DSPs and they have their own RTOS that is free called Visual DSP++ Kernel.
The code that was involved in that project:
Digital filters
A PID controller
Network interfaces (pretty basic, nothing fancy)
Self test code
System test code (monotored system dynamics to make sure there wasn't a problem)
For the coding: The controller itself is easy to write (as are the digital filters). Tuning those to work together to get the best results is the harder part.
Don't be scared by RTOSes, threads, etc. For a system like the one above the filters and PID controller need threads of different priorities to make sure everything gets run periodically and at the correct rates. Sometimes that takes some juggling, head scratching, and optimization... but that is part of engineering.
I have never actually done an entire control design in an FPGA though it is definitely possible (especially the ones with embedded processors). Usually my FPGA work has been as part of a CCA design where the FPGA does hardware interface support (like if you were designing a PCI card that had a bunch of A/D converters on it the FPGA would implement the PCI bridge and control all the A/D converters).
Hey,
Thanks for the info, Floid. That was very helpful. Embedded stuff still scares me, but at least I'll be able to make an informed decision in picking my concentration. Thanks! :)
