Calculating Moment of Inertia and Angular Motion of Stick
The discussion focuses on calculating the moment of inertia and angular motion of a stick with mass M = 7.6 kg and length L = 0.8 m, pivoted 0.13 m from one end. The moment of inertia about the axle is determined using the parallel-axis theorem, yielding Iaxle = 1.621333 kg m². The angular speed as the stick passes through the vertical is calculated to be w = 5.424 rad/s, while the angular acceleration at this position is 0 rad/s². The vertical force exerted by the stick on the axle is also discussed, emphasizing the application of energy conservation principles.
  • Understanding of the parallel-axis theorem
  • Knowledge of moment of inertia calculations for rigid bodies
  • Familiarity with conservation of energy principles
  • Basic concepts of angular motion and dynamics
  • Study the derivation and applications of the parallel-axis theorem
  • Learn about the moment of inertia for various shapes and configurations
  • Explore conservation of energy in rotational motion
  • Investigate angular dynamics and the effects of torque on motion
Physics students, mechanical engineers, and anyone interested in the dynamics of rigid body motion and rotational mechanics.
Naeem
A stick of uniform density with mass M = 7.6 kg and length L = 0.8 m is pivoted about an axle which is perpendicular to its length and located 0.13 m from one end. Ignore any friction between the stick and the axle.
a) What is the moment of inertia of the stick about this axle?
Iaxle = kg m2
1.621333 NO
HELP: Use the parallel-axis theorem.
i.e Icom + Mh2, how to apply that here.
The stick is held horizontal and then released.
b) What is its angular speed as it passes through the vertical
w = rad/s
c) What is its angular acceleration as it passes through the vertical position?
a = rad/s2
d) What is the magnitude of the vertical component of the force exerted by the stick on the axle when the stick passes through the vertical?
|Fvertical| = N
Somebody help me with all these parts!
did you figure out part d yet i am working on the same problem
a) Using the parallel-axis theorem, we can calculate the moment of inertia of the stick about the axle as:
Iaxle = Icom + Mh^2
Where Icom is the moment of inertia of the stick about its center of mass, M is the mass of the stick, and h is the distance between the center of mass and the axis of rotation (in this case, h = 0.13 m).
We can calculate Icom for a thin rod rotating about its center of mass using the formula:
Icom = (1/12)ML^2
Plugging in the given values, we get:
Icom = (1/12)(7.6 kg)(0.8 m)^2 = 0.512 kg m^2
Therefore, the moment of inertia of the stick about the axle is:
Iaxle = 0.512 kg m^2 + (7.6 kg)(0.13 m)^2 = 1.621333 kg m^2
b) When the stick passes through the vertical position, it will have converted all of its potential energy into kinetic energy. Using the conservation of energy, we can calculate the angular speed as:
1/2Iw^2 = mgh
Where I is the moment of inertia, w is the angular speed, m is the mass, g is the acceleration due to gravity, and h is the height of the stick's center of mass.
Since the stick's center of mass starts at a height of 0.8 m and ends at a height of 0.13 m, we can calculate the height as:
h = (0.8 m + 0.13 m)/2 = 0.465 m
Plugging in the values, we get:
1/2(1.621333 kg m^2)(w)^2 = (7.6 kg)(9.8 m/s^2)(0.465 m)
Solving for w, we get:
w = √((2(7.6 kg)(9.8 m/s^2)(0.465 m))/(1.621333 kg m^2)) = 5.424 rad/s
c) Since the stick is rotating at a constant speed as it passes through the vertical, its angular acceleration is 0.
d) At the vertical position, the stick is exerting
  • · Replies 45 ·
  • · Replies 18 ·
