New Reply
Rotation around a tilted axis.
Share Thread Thread Tools
Nov5-11, 09:12 AM   #1
I am writing a little code that should make an object revolve around a tilted axis.
Here is what I have:
-The center coordonates
-A normal array (3 numbers between 0 and 1);
-position of the object.
Is there a way to do this?
I think:
http://en.wikipedia.org/wiki/Rodrigu...tation_formula
Should be it , but I can't work out how to use it. Does the formula return an array?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov9-11, 10:51 AM   #2
Recognitions:
Which formula in that article are you talking about?
If you want a conceptually simple way of doing it, consider this:
Do you know how to write code that would change from one coordinate system to another? If you change coordinates so that the "center" of the rotation becomes the origin in the new coordinate system and the axis of rotation becomes the z-axis in the new coordinates system then you can apply the formula for rotating an object about the z-axis. Get the coordinates of interest in the new coordinate system and then transfer those coordinates back to the original coordinate system.
I've read articles by people who do computer animation that say that using quaterions is the best way to deal with the motion of objects. Are you doing animation?
Nov9-11, 06:39 PM   #3
Quote by cake21 View Post
I think:
Hey cake21 and welcome to the forums.
One method you might want to consider is to use quaternions and then after you computer the final output quaternion, convert it to a linear transformation (matrix) and then apply that matrix to the points you need to do.
The reason why I recommend this is because if you want to multiple rotations, or some something like rotation interpolations, quaternions are probably the best way of doing this, and building a quaternion library is not a hard thing to do either.
New Reply
Thread Tools
Similar Threads for: Rotation around a tilted axis.
Thread Forum Replies
2-axis rotation to 3-axis lift Advanced Physics Homework 1
How to find angular momentum of a body about an axis other than the axis of rotation? Introductory Physics Homework 11
earth's axis of spin w.r.t. galactic rotation axis General Astronomy 6
If the Earth's axis was tilted 45 degrees.. Biology, Chemistry & Other Homework 2
Rotation about axis in R3 Calculus & Beyond Homework 9
