Universe expansion + light speed limit -> scale factor linear in time?
The discussion revolves around the relationship between the expansion of the universe, the speed of light, and the implications for the scale factor in cosmology. Participants explore whether the scale factor can be linear in time based on these premises, examining both theoretical and observational aspects of cosmological models.
  • One participant defines the Hubble parameter and proposes that it indicates uniform expansion of space, leading to a linear time dependence of the scale factor, a(t) = H_0 * t.
  • Another participant agrees that in an open universe without a cosmological constant, the scale factor behaves as a(t) ∝ t, but raises concerns about curvature terms affecting this relationship.
  • A participant identifies a potential error in the derivation regarding the Hubble radius, suggesting that the relationship presented does not logically follow from previous statements.
  • It is noted that each age of the universe has its own Hubble radius, and the implications of this for the distribution of galaxies are discussed.
  • One participant argues that in General Relativity, there is no global speed limit, only local limits, and challenges the idea that the speed of light constrains the Hubble expansion rate.
  • Another participant elaborates on the concept of the observable universe and its relationship to the Hubble radius, suggesting that assuming a linear scale factor leads to an infinite observable radius.
  • Concerns are raised about the interpretation of velocities in cosmology, particularly regarding the proper velocity in the Hubble relation and its implications for redshift.
Participants express multiple competing views regarding the implications of the speed of light on cosmological expansion and the validity of a linear scale factor. There is no consensus on the correctness of the proposed models or interpretations.
Some participants highlight limitations in the assumptions made, particularly regarding the nature of velocities in cosmological contexts and the implications of curvature on expansion rates. The discussion remains open to interpretation and refinement.
johne1618
The Hubble parameter is defined by:
H(t) = a'(t) / a(t)
where a is the scale factor which is a function of cosmological time t.
This definition is equivalent to the Hubble relation:
v(t) = H(t) r(t)
where v(t) and r(t) are the proper velocity and distance of an object at cosmological time t.
I assume that this relationship is exact provided that we acknowledge that the Hubble parameter H(t) is constant only in space and *not* in time. It can be interpreted as simply asserting that space is expanding uniformly at a rate H(t).
Now let us assert that a universal speed limit exists, namely the velocity of light c. We know this is true observationally as the redshift diverges as v -> c.
This assumption allows us to define the Hubble radius R(t) by
c = H(t) R(t).
Then the Hubble radius, R_0, at the present time t_0 is given by:
c = H_0 R_0
where H_0 is the present Hubble parameter value.
As we have:
R(t) = R_0 a(t)
R(t) = (c / H_0) * a(t)
Therefore
a'(t) / a(t) = c / R(t)
a'(t)/ a(t) = H_0 / a(t)
So that finally
a(t) = H_0 * t
or equivalently
R(t) = c * t
Thus we seem to have derived a scale factor with a linear time dependence using only two facts:
1. Space is expanding uniformly.
2. A cosmological speed limit, namely c, exists.
Is this correct?
I expect I'm also assuming that space is flat.
This very simple scale factor time dependence, the so-called coasting cosmology, is actually close to what is observed.
Space news on Phys.org
It is true that the late time behaviour of an open universe with no cosmological constant is given by:
a [itex]\propto[/itex] t
But I think the curvature term: - k / [itex]a^{2}[/itex]
Does not limit the expansion to c.
John, you made an error in your derivation about 15 lines from the bottom where you said:
R(t) = R_0 a(t)
It does not follow from the preceding stuff.
Each age has its own Hubble radius R(t). It is not simply equal to the Hubble radius of some other age, subjected to normal scalefactor expansion. If that were true the Hubble volume would always contain the same set of galaxies (expect for changes due to their individual random motions).
It's good to see all the algebra, almost all steps of which are correct. And you are digging into the actual definitions and exploring their consequences---the right thing to be doing. Just that one mistake.
Also, in General Relativity, there cannot be any global speed limit. There is a local speed limit, meaning that objects cannot ever outrun light rays (any observer anywhere always sees light moving past them moving at c). But there is no unique way to define the velocity of far-away objects. So it turns out that the velocity of far-away objects just depends upon the way we write down our coordinates, and we can just as easily say something far away has no motion relative to us, is moving away at the speed of light, or is moving away at twice the speed of light. It makes no difference.
The only time that relative velocity is well-defined is when you are comparing two velocities at a single point. So it is only then that the speed of light limitation makes sense.
Thus the idea that the speed of light could possibly impose a limit on the Hubble expansion rate is just incorrect.
Thanks for the replies - very helpful!
But if one wanted to assert that the Hubble Radius R(t) is the "radius of the Universe" then one would want it to be constant in the comoving frame (the frame in which the Universe is static with respect to time)
I realize that the radius of the "observable" universe can be larger than the Hubble radius because objects that we see now have been expanding away from us as the light from them traveled to us. That distance depends on the time dependence of the scale factor.
In fact if one assumes a scale factor that is linear with time for all times then one finds that the radius of the observable universe is actually infinite whereas the Hubble radius is equal to the speed of light times the age of the Universe. Rather neat I think. The Hubble radius is thus the radius of the lightcone of events since the Big Bang that can effect us now.
To explain: The radius of the observable universe is given by:
Observable Radius = Integral [t=t_s:t_0] c dt' / a(t')
where t_0 is the present age of the universe and t_s is the starting time of the Universe.
If we assume a linear scale factor time dependence then:
a(t') = t' / t_0
where t_0 is the present age of the Universe.
Thus substituting into the above expression for the observable radius and doing the integration we find:
Observable radius = c t_0 ln (t_0 / t_s)
As t_s -> 0 the observable radius -> infinity.
We seem to get a flat infinite Euclidean space popping out of a point in a finite time which is rather interesting.
Except the universe isn't static with respect to time, no matter your frame of reference.
According to the Wikipedia entry on comoving distance:
Space in comoving coordinates is usually referred to as being "static", as most bodies on the scale of galaxies or larger are approximately comoving, and comoving bodies have static, unchanging comoving coordinates. So for a given pair of comoving galaxies, while the proper distance between them would have been smaller in the past and will become larger in the future due to the expansion of space, the comoving distance between them remains constant at all times.
John, I probably was too complimentary and encouraging in my post #4. I picked out an error 15 lines from the end and said "only that one mistake". I should have emphasized that the train ran off the track at that point. Your conclusions in the last 15 lines are wrong as a consequence.
In your latest post you do begin to sound a bit crackpotty, so I urge you to back off and take stock of the situation. Please do not press on with the mistaken assumptions of time-linear scalefactor and "universal speed limit" on the distance expansion rate.
I should have pointed out there was some conceptual trouble early in your post #1. The v(t) in the Hubble relation is not an ordinary velocity, and is not governed by the velocity speed limit. But you refer to it as a "proper velocity"
==quote John post #1==
v(t) = H(t) r(t)
where v(t) and r(t) are the proper velocity and distance of an object at cosmological time t...
...Now let us assert that a universal speed limit exists, namely the velocity of light c. We know this is true observationally as the redshift diverges as v -> c.
==endquote==
If v is the expansion rate in the Hubble relation the redshift certainly does not diverge :biggrin:. It approaches something like 1.4 as v -> c.
The divergence of the Doppler shift as velocity approaches c is in the fixed non-expanding frame of special relativity, Minkowski space. That does not apply at cosmological distances.
I dimly suspect that you know this already, but perhaps that is overly pessimistic.
There is still the curvature of space-time, in any coordinate system, that means that it just doesn't fit the definition of static. There's also the point to be made that even in a coordinate system where the average coordinate distance between far-away galaxies doesn't change, you still get the formation of galaxy clusters, galaxies, and smaller objects.
14K
  • · Replies 93 ·
  • · Replies 22 ·
