Infinite Product of (1+a2n-1)(1+a2n) - Math Help
  • Context: Graduate
  • Thread starter Thread starter euclid3.14
The discussion revolves around the infinite product of the sequence defined by \( a_n = \frac{(-1)^{n-1}}{n} \) and its implications for convergence. Participants explore the product \( \prod_{n=1}^{\infty}(1+a_n) \) and related infinite products, including the convergence behavior of specific formulations.
  • Some participants inquire whether working out \( (1+(a_{2n-1}))(1+a_{2n}) \) aids in determining the infinite product.
  • One participant suggests that the product can be calculated for a finite number of even terms, \( \prod_{n=1}^{2k}(1+a_n) \), and questions how to approach the odd terms.
  • Another participant claims to have found the product equals 1 but is cautioned that this conclusion requires absolute convergence.
  • There is a discussion about the convergence of the product \( \prod_{n=1}^{n}(1-1/(n+1)^2) \) and its relation to the convergence of the series \( \sum \frac{1}{(n+1)^2} \).
  • Participants explore the simplification of the product and propose finding a general expression for \( \prod_{n=1}^{k}(1-1/(n+1)^2) \) by examining specific cases.
  • One participant expresses uncertainty about the convergence of the odd term product and its relationship to the even term product.
  • Another participant discusses the implications of subsequences on convergence, emphasizing that different limits in subsequences indicate the original sequence does not converge.
  • There are attempts to express the partial products in terms of simpler fractions, with observations about their behavior as \( n \) approaches infinity.
Participants express differing views on the convergence of the infinite products and the implications of subsequences on convergence. No consensus is reached regarding the conclusions drawn from the calculations.
Participants highlight the need for absolute convergence to draw conclusions about the convergence of the infinite product. There are unresolved questions regarding the behavior of the products of odd and even terms.
This discussion may be of interest to those studying infinite products, convergence in sequences, and mathematical reasoning in the context of series and products.
euclid3.14
Hi, if an = (-1)^n-1 /n what is the infinite product of (1+an)
does working out (1+(a2n-1))(1+a2n) help? :rolleyes:
Yes it does, what did you get? You should then be able to work out the product up to any finite number of even terms, [itex]\prod_{n=1}^{2k}\left(1+a_n\right)[/itex]
Can you do a similar thing (though this will be a bit trickier) to work out the product for a finite number of odd terms, [itex]\prod_{n=1}^{2k+1}\left(1+a_n\right)[/itex]?
Thanks for the responce!
I got it to eqaul 1 (think that's right!) I take it that this means the infinite product therefore converges to 1?
Have another querry on infinite products. what does [itex]\prod_{n=1}^{n}\left(1-1/(n+1)^2\right)[/itex]? converge to? I've write out the seris to get ((n+1)^2-1(n+2)^-1...) / ((n+1)^2*(n+2)^2...)
As the sum of 1/(n+1)2 converges I know that the infinite product must converge!
Not so fast, you can only conclude that if it converges then it converges to 1. You can't sum it 2 terms at a time unless you know the thing is absolutely convergent. Consider [itex]\sum(-1)^n[/itex]. If you look at the partial sum of an even number of terms, you get 0, but you wouldn't say this sum converges based on that.
You'll want to look at the product of an odd number of terms. What is [itex]\prod_{n=1}^{2k+1}\left(1+a_n\right)[/itex] in terms of k? Use the fact that you know what the product of an even number of terms is...
Can you find a nice expression for [itex]\prod_{n=1}^{k}\left(1-1/(n+1)^2\right)[/itex] for any value of k? Try finding the product for k=1,2,3,4,5 and see if you can guess a nice formula (find more than 5 if you need to). Try to prove your formula is correct and use it to find the limit.
shmoe said:
Not so fast, you can only conclude that if it converges then it converges to 1. You can't sum it 2 terms at a time unless you know the thing is absolutely convergent. Consider [itex]\sum(-1)^n[/itex]. If you look at the partial sum of an even number of terms, you get Don't you mean 1 here? , but you wouldn't say this sum converges based on that.
Doesn't it tend to one as n tends to infinity as you take the module of the series?
There's a chance that I'm confused!
could simplify it to [itex]\prod_{n=1}^{k}\left((n+1)^2 -1)/(n+1)^2\right[/itex] or [itex]\prod_{n=1}^{k}\left(n^2 +2n /n^2 +2n +1\right)[/itex]
Code:
k 1 2 3 4 5
3/4 2/3 5/8 3/5
Seems to be tending to 1/2 but how would could i explain that properly? :confused:
Cheers you the responce, it's been very helpful! :smile:
I did mean 0. Let me be more precise, let [itex]S_k=\sum_{n=1}^{k}(-1)^{n}[/itex]. Then for any k we have [itex]S_{2k}=0[/itex], and [itex]S_{2k+1}=1[/itex], which you can see by pairing up the terms. Thus [itex]\lim_{n\rightarrow \infty}S_{2k}=0[/itex] but [itex]\lim_{n\rightarrow \infty}S_{k}[/itex] does not exist since this sequence of partial sums jumps back and forth between 0 and 1.
The moral is you cannot conclude a sequence converges if all you've shown is the convergence of a subsequence. Hence, I suggest you look at the sequence of partial products containing an odd number of terms to make sure it's behaving.
Code:
k 1 2 3 4 5
3/4 2/3 5/8 3/5
For your first five partial sums, 3/4, 2/3, 5/8, 3/5, 7/12, do you see any relation between them and the correspodning k values? Let me rewrite these five terms as 3/4, 4/6, 5/8. 6/10, 7/12. Can you express these numerators and denominators as a function of k?
I would like to add something about sequences and subsequences.
That's right that you can't conclude about the convergence of a sequence only working on his subsequences...in the most cases.
Indeed, if two subsequences has two different limits, then the sequence has no limit (because if a sequence has a limit, then all its subsequences have the same limit).
And, a very useful tip. If [tex](U_{2k})[/tex] and [tex](U_{2k+1})[/tex] have the same limite then [tex](U_{k})[/tex] too.
And that's still right if [tex](U_{3k})[/tex],[tex](U_{3k+1})[/tex],[tex](U_{3k+2})[/tex] converge.
Back to the problem of this thread :).
[tex]\prod_{k=1}^{n} 1-\frac{1}{(k+1)^{2}}=\prod_{k=1}^{n} \frac{(k+1)^{2}-1}{(k+1)^{2}}=\prod_{k=1}^{n} \frac{k+2}{k+1}\times\frac{k}{k+1}=\prod_{k=1}^{n} \frac{k+2}{k+1}\prod_{k=1}^{n}\frac{k}{k+1}[/tex]
Then you can easyly conclude ;).
Thanks for the help. I've written the sum as (n+2)/ 2(n+1) which tends to 1/2 as n tends to infinity.
I also got the odd term to converge to one as p(2n+1) = p2n*a(2n+1) and as p2n tends to 1 and a(2n+1) tends to 1 as well then the odd term tends to one! :bugeye:
  • · Replies 20 ·
