New Reply
Calculation of RMS Voltage and Current
Share Thread Thread Tools
Nov18-11, 03:30 AM   #1
I've a theoretical circuit that resembles an on-off switch with a duty cycle of 50%. The voltage input to the circuit is a constant 5v. The current drawn from the source is 1A when switch is ON and 0A when OFF. What is the Vrms and Irms?
From what I know:
Vrms for constant 5v is 5v.
Irms for above current (square wave with 50% duty cycle) would be I/√2 = 1/√2.
This imples P=Vrms*Irms = 5/√2
However, if we separately do some calculations for power, it would be like 5*1*0.5 (V*I*duty chle) = 5/2.
Can this discrepancy be explained please? Please let me know what am I missing.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Nov18-11, 04:04 AM   #2
Quote by vinayakbhat82 View Post
From what I know:
Prms = Vrms * Irms is only valid for a purely resistive load.
If you have a battery, a switch and a resistor in series, you can consider V and I across the resistor, and V won't be constant, so Vrms isn't 5V.
You can also consider V and I across the resistor and switch, and then Prms = Vrms * Irms
isn't valid and you have to do an integral of V(t)*I(t) over one cycle.
Nov18-11, 05:27 AM   #3
Hey willem2,
Thanks for the reply.
Yes, I did have that idea earlier, but I was trying to answer the following: If I've a blackbox that has the circuit you mentioned i.e. switch and a resistor with no access to internal nodes and I need to have a DC equivalent of the original source that delivers the same power, how would I arrive at the numbers if I was provided with the voltage and current waveforms at the boundary. By reverse engineering, we may say that Vrms needs to be 5/√2 in this case, however, I wanted to understand the rationale behind doing so.
I completely agree to your point that the rms voltage across the resistor would not be 5v, but would rather be 5/√2.
Is there a term called Prms or is it just P/ If so, please help me understand. Also I believe, integrating V*I over time will give you Energy.
Nov18-11, 06:24 AM   #4
There's no Prms, just average power.
The integral indeed gives the energy used in one period, so you'll have to divide by the length of the period to get the average power.
Nov18-11, 01:43 PM   #5
This is valid only for a sine wave. ie the I/√2
New Reply
Tags
power, rms current, rms voltage
Thread Tools
Similar Threads for: Calculation of RMS Voltage and Current
Thread Forum Replies
Figuring out voltage across resistor and current in loop given initial voltage input Engineering, Comp Sci, & Technology Homework 2
Why is there a flatband voltage in the calculation of Threshold voltage? Introductory Physics Homework 0
voltage and current calculation on a mixed circuit Introductory Physics Homework 2
current to voltage conterter and voltage to current converter Engineering, Comp Sci, & Technology Homework 3
