Differentiation, related rates?
The discussion centers on maximizing the area of a rectangle inscribed in a right triangle using calculus. The area \( A \) is expressed as \( A = xH - \frac{H}{b}x^2 \), where \( H \) is the height and \( b \) is the base of the triangle. Participants clarify the differentiation process and suggest using the vertex of the parabola to find the maximum area instead of relying solely on derivatives. The equation of the hypotenuse is given as \( y = H - \frac{H}{b}x \), which is crucial for setting up the problem.
  • Understanding of calculus, specifically differentiation and related rates
  • Familiarity with the properties of right triangles
  • Knowledge of maximizing functions and the vertex of a parabola
  • Basic algebra for manipulating equations
  • Study the differentiation of polynomial functions, focusing on the power rule
  • Learn about maximizing area problems in geometry, particularly with inscribed shapes
  • Explore the method of completing the square for quadratic equations
  • Investigate related rates problems in calculus for further applications
Students studying calculus, particularly those focusing on optimization problems, geometry enthusiasts, and educators looking for examples of applying calculus to real-world scenarios.
Willowz
Determine the dimensions of the rectangle of largest area that can be inscribed in the right triangle shown?
AB/AD = BC/DE
I've been trying to do this problem. I looked online and saw an explanation without directly using the area of the triangle, found http://answers.yahoo.com/question/index?qid=20101128161728AA21pl7".
Can someone remind me how to differentiate A = x H - (H/X)x^2 , in the last part of the problem? Is this from related rates?
Picture added:
lCBl = X
lABl = H
H/h = X/x
I'm not sure exactly what you want here. You have not given any dimensions for the triangle.
Assuming a right triangle of base b and height h, we can set up a coordinate system having the two legs as axes. Then the hypotenuse is a line from (0, h) to (b, 0). The equation of that line is y= h- (h/b)x. Let a be the length of the rectangle along the x-axis, b, the length of the rectangle along the y-axis. Since the fourth vertex must lie on the hypotenuse, a and b must satisfy b= h- (h/b)x. Maximize the area, ab, with the constraing b= h- (h/b)a. Yes, that gives A= a(h-(h/b)x)= ah- (h/b)x2, just what you have with a slightly different notation.
As far as differentiating Hx- (H/X)x2, one of the very first derivative rules you learned is that the derivative of [itex]x^n[/itex] is [itex]nx^{n-1}[/itex]. However, you don't really need to use the derivative to maximize this. Complete the square to find the vertex of the parabola.
  • · Replies 30 ·
