Register to reply
Why Ax=0 only has trivial solution
by georg gill
Tags: solution, trivial
Share this thread:
georg gill
#1
Nov22-11, 02:04 AM
P: 100
Ax=0 has only trivial solution if A is row equivalent to I. Here in theorem 6 they explain it by referring to another theorem 4 in my book:
Theorem 6
http://bildr.no/view/1032481
Theorem 4:
http://bildr.no/view/1032482
Why is it so that if A is invertible Ax=0 only has trivial solution for x.
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Theorem.
#2
Nov22-11, 02:17 AM
P: 237
This is true because a matrix is invertible if and only if its column vectors are all linearly independent (If the columns are linearly dependent on the other hand, the matrix will have determinant zero and thus not be invertible)
i.e. if A has column vectors [itex]v_1,...,v_n[/itex], then those vectors are linearly independent if and only if the equation [itex]a_1v_1 +...+a_nv_n\cdot =0[/itex] has only the trivial solution [itex]a_1=...=a_n=0[/itex] This is equivalent to saying [itex]Ax=0[/itex] has only the trivial solution. To see this, write the linear independence expression in matrix notation.
georg gill
#3
Nov22-11, 02:31 AM
P: 100
I get it when I say that the column vectors are linearly independent (as you point out) but when one reduce a matrix to its identity matrix one will get I if the rows are independent. How does this show that also the columns are independent?
Theorem.
#4
Nov22-11, 02:39 AM
P: 237
Well do you remember how you find the inverse of a matrix? you reduce it alongside the identity, i.e. reduce [itex](A|I_n)[/itex], If you can arrive at the identity via row reduction, then A is invertible. And a matrix is invertible if and only if the columns are independent. The two statements go hand in hand, each implies the other. Alternatively, you know that the Identity matrix has linearly independent column vectors. It follows that if you can reduce a matrix by performing elementary row operations into the identity, then the original column vectors must be linearly independent.
georg gill
#5
Nov22-11, 03:18 AM
P: 100
This proof should also show it
http://en.wikipedia.org/wiki/Rank_(l....3D_rk.28AT.29
right?
Theorem.
#6
Nov22-11, 03:43 AM
P: 237
Yes,correct
Register to reply
Related Discussions
If det(A)!=0, Ac=0 has only trivial solution Calculus & Beyond Homework 2
Question Ax = 0 has only trivial solution and Ax = b has 1+ solution for every b Linear & Abstract Algebra 2
Linear algebra proof with trivial solution Calculus & Beyond Homework 6
Is the trivial solution a unique solution? Linear & Abstract Algebra 4
Trivial solution method for constant coeff case Differential Equations 15
