What does an exact solution to a pde mean?
  • Context: Undergrad
  • Thread starter Thread starter myshadow
    Mean Pde
An exact solution to a partial differential equation (PDE) is defined as a particular solution that satisfies the boundary conditions (b.c.) and initial conditions (i.c.) without the use of approximation methods. Most differential equations do not yield exact, analytic solutions that can be expressed in simple forms like f(x) = Ae^{kx^2} + Bx^2. While a particular solution qualifies as an exact solution, it is distinct from the general solution, which encompasses a broader set of solutions. It is important to note that some discussions may conflate exact solutions with general or analytic solutions.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary conditions (b.c.) and initial conditions (i.c.)
  • Knowledge of analytic solutions and general solutions in differential equations
  • Basic concepts of approximation methods in solving differential equations
  • Study the differences between exact solutions and general solutions in PDEs
  • Explore methods for finding particular solutions to PDEs
  • Learn about common approximation techniques used in solving differential equations
  • Investigate specific examples of PDEs with known exact solutions
Mathematicians, physicists, and engineering students who are studying differential equations and seeking to understand the nuances of exact and approximate solutions in the context of PDEs.
myshadow
I've always heard the phrase "exact solution," but was never really sure what it meant. If I find a particular solution (not a general solution) to a PDE, is that solution considered an "exact solution"? (The solution satisfies given b.c. and i.c.)
An exact solution means that no approximation methods were used. MOST differential equations do not have exact, analytic solutions that you could write out as say, [itex]f(x) = Ae^{kx^2} + Bx^2[/itex]; some nice simple function that works for all 'x'. Most equations require you to make assumptions about parts of the differential equation such as having to assume 'x' is much greater than some constant in the problem or that various values in the differential equation have certain realistic properties that make the equation solvable using approximate solutions. This is a quick answer as I don't have much time but there's other examples.
A particular solution is an exact solution, but it is not the general solution.
Some people actually mean the general solution (or analytic solution) when they say exact solution.
u=0 is often an exact solution to a differential equation, but not a very interesting one and usually also not the general solution.
  • · Replies 36 ·
