Transformation of A = transpose[A] for mxn Matrices
The transformation T: M2,3 → M3,2, defined by T(A) = AT, requires the correct representation of the transformation matrix B. The key issue arises from the dimensions of B; it must be a 3x2 matrix to produce a 2x3 matrix when multiplied by A. However, the multiplication rules dictate that a 3x2 matrix cannot yield a 2x3 matrix directly. The solution involves representing matrices as single columns of 6 numbers to facilitate the transformation.
  • Understanding of matrix multiplication rules
  • Familiarity with matrix dimensions and transformations
  • Knowledge of linear algebra concepts
  • Experience with matrix representation as column vectors
  • Study the properties of matrix transformations in linear algebra
  • Learn about representing matrices as column vectors
  • Explore the implications of matrix dimensions in transformations
  • Investigate examples of similar transformations in M2,n and M3,n
Students studying linear algebra, educators teaching matrix transformations, and anyone involved in mathematical modeling using matrices.
spybloom
"Let T:M2,3→M3,2 be represented by T(A) = AT. Find the matrix for T relative to the standard bases for M2,3 and M3,2"
I let the transformation matrix be B. I know that BA = AT, so I need some matrix times A to equal A transpose.
I'm having problems just trying to figure out the size of B. If B is 3x2, then the resultant matrix would be 3x3, which wouldn't equal the size of AT. I've tried playing around with adding a row of zeros to the bottom of A, but then I can't figure out the contents of B. Quite frankly, I'm stumped.
I presume that you know that if you multiply an m by n matrix by an n by p matrix, you get a m by p matrix. You cannot multiply any matrix by a 3 by 2 matrix and get a 2 by 3 matrix. In order to be able to write this transformation as a matrix, you will have to write your matrices as single columns of 6 numbers.
  • · Replies 18 ·
12K
