Another solving trigomonetry equation for x
  • Thread starter Thread starter songoku
The discussion revolves around solving a trigonometric equation involving sine, cosine, tangent, cotangent, secant, and cosecant functions. Participants are exploring various approaches to manipulate the equation and seek solutions.
  • Participants discuss taking a common denominator and substituting variables to simplify the equation. Some express uncertainty about how to apply trigonometric identities effectively. Others question the validity of derived equations and explore the implications of squaring both sides of an equation.
The conversation is ongoing, with participants sharing insights and corrections to previous attempts. Some have suggested methods to derive polynomial forms from the original equation, while others are verifying the correctness of solutions against the original equation.
There is mention of potential extraneous roots introduced through algebraic manipulation, and participants are encouraged to check their solutions against the original equation. The complexity of the problem and the variety of approaches indicate a rich exploration of the topic.
songoku
Solve:
sin x + cos x + tan x + cot x + sec x + cosec x + 2 = 0
trigonometry
The best I can get is:
sin2x cos x + cos2x sin x + sin x + cos x + 3 = 0
Then...:cry:
ArcanaNoir said:
This page has more trig identities than I even knew existed. Maybe you can find something here that will help. http://www.sosmath.com/trig/Trig5/trig5/trig5.html
I know those identities but I don't know how to use it to solve the problem :redface:
Take everything to a common denominator first. Then make [itex]\sin x = p[/itex] to obtain an algebraic eqn in p.
Sorry I couldn't be more helpful. I'm not deliberately being unhelpful, I did try to solve the equation, just haven't gotten anywhere on it. :(
I've done that. I got sin2x cos x + cos2x sin x + sin x + cos x + 3 = 0 as in my first post
So,
p2 √1-p2 + (1-p2) p + p + √1-p2 + 3 = 0
Can it be solved?
No problem. Thanks for the link :smile:
my calculator said:
[tex]x=2\cdot \pi \cdot \textrm{constn} (1)-\frac{\pi }{4} ,[/tex]
[tex]x=2\cdot \pi \cdot \textrm{constn} (2)+\frac{3\pi }{4}[/tex]
I don't see this one working out nicely. >_<
Wolfram can solve the original equation directly.
He also rewrites it into a product of trig functions.
The question is how to get there without too much hassle...
The cavalry is here! :D
songoku said:
Solve:
You made a mistake when you derived the second equation.
You forgot to multiply 2 with (sin x cos x).
If you fix that, you can apply for instance dextercioby's method.
If you work it out, you should be able to get a 3rd degree polynomial that you can solve.
Your attitude towards me seems to have shifted somewhat, since we've first met. ;)
Thanks for the vote of confidence!
The only elementary thing you can immediately deduce from that equation is that if theta is a solution, then (pi/2 - theta) is also a solution.
This follows immediately from the fact that replacing x with (pi/2 - x) in the equation changes nothing.
I can't see a shortcut to a rigorous full solution. However, simple inspection immediately yields -pi/4 as a solution, since one needs to find a value where the numerical values of the sine and cosine have to be equal in magnitude and of opposite sign so they cancel out (and the same would apply to the sec and cosec terms), and where the tangent and cotangent are both equal to -1, so they would add to -2 and cancel out the +2 constant term.
Having found -pi/4 as a solution, we known that pi/2 - (-pi/4) = 3pi/4 is also a solution.
One can immediately add the requisite 2k*pi to each of those solutions for the general solution set. Problem is, one can never be sure one is not missing some obscure solution(s) with this sort of slipshod "easy" method.:frown:
Ops my bad. The equation should be:
sin2x cos x + cos2x sin x + 1+ sin x + cos x + 2 sin x cos x = 0
let sin x = p
p2√1-p2 + p - p3 + 1 + p + √1-p2 + 2 p √1-p2 = 0
After some works, the equation becomes:
(p + 1) [(√1-p2)(p+1)-p2+p+1)] = 0
To solve [(√1-p2)(p+1)-p2+p+1)] = 0 :
(√1-p2)(p+1) = p2-p-1
squaring both sides and doing some works, I got:
2p4 - p3 - p2 + p = 0
p (2p3 - p2 - p + 1) = 0
p = 0 or 2p3 - p2 - p + 1 = 0
But when I subs p = 0 to (p + 1) [(√1-p2)(p+1)-p2+p+1)] = 0, it is not correct. So it means that p = 0 is extra root?
Then, how to solve 2p3 - p2 - p + 1 = 0 ??
Thanks
Yep! I'm with you so far.
I get something else, so I think you made a mistake somewhere...
Yeah...:-p
Maybe it should be like this:
2p4 - p2 = 0
Am I correct?
Yes! That looks much simpler! :)
Then p = 0 is extra root? Because it is not correct when I subs. it into (√1-p2)(p+1) = p2-p-1
Yes, p=0 is an extra root that was introduced when you squared both sides of the equation.
If you substitute it, you'll find 1=-1.
When you square both sides, you get 1=1, which is the reason you found it as a solution.
As you can see, you have to verify each solution against the original equation to see if it really is a solution.
Ok. Thanks a lot for your help :)
Thanks!
But then, that's what the cavalry is for. ;)
  • · Replies 26 ·
