Kinetic Energy of the Products of Nuclear Reaction?
The discussion revolves around calculating the total kinetic energy of the products from a nuclear reaction involving deuteron and carbon-13, resulting in nitrogen-14 and a neutron. Participants are exploring the relationship between kinetic energy and rest mass energy in the context of nuclear reactions.
  • Participants discuss the conservation of energy and momentum in nuclear reactions, questioning how to account for rest mass energies and kinetic energies of the reactants and products. There are attempts to calculate the Q value and relate it to the kinetic energy of the incoming deuteron.
The discussion has seen various attempts to calculate the kinetic energy, with participants sharing their calculations and questioning their methods. Some have expressed confusion about the correct approach and the assumptions involved, while others have provided insights into the relationship between total energy and kinetic energy.
Participants are operating under the assumption that certain particles are at rest, and there is a focus on the conversion of mass to energy using the provided mass-energy equivalence factor. There is also mention of the need to clarify the definitions of kinetic energy and rest mass energy in the context of the problem.
JayRemmy
Calculate the total kinetic energy of the products of the reaction d+C-13 --> N-14 + n if the incoming deuteron (d) has 36.3 MeV.
Q=(Parent Mass - Daughter Mass - Decay Particle Mass)*c^2
1u = 931.5 MeV
C-13 = 13.00335u
N-14 = 14.003241u
Neutron = 1.008664u
deuteron = 2.014101
KE before = KE after
Alright I'm kinda lost on this problem though I feel it's easy. Since KE before=KE after I took the energy of the deuteron (36.3 MeV) and added that to the resting energy of C-13, which I got to be 13.00335*931.5= 12112.6MeV
Now I thought that would be the answer, but it wasn't, so I tried subtracting the mass of the products from the mass of the reactants to get the Q value. So I took (2.014101+13.00335)-(14.003241+1.008664)=.005546u*931.5MeV/c^2= 5.1661MeV,
...but that wasn't right either so I'm confused as to what I'm actually trying to find. If someone could tell me what I'm solving for and what equation to use? Or if I have a wrong conversion factor or isotope mass? Thanks!
No, total energy before equals total energy after (not just kinetic). Momentum before equals momentum after, however.
I understand but can I find momentum for C-13 if there is no velocity? The only thing I can think of is to do KE=p^2/2m, but that doesn't give me the right answer either. I ended up getting 10261.7 MeV.
You shouldn't need momentum since you have the rest mass energies of the reactants, the KE of the deuteron (the others are assumed to be at rest from the problem description), and the rest masses of the products.
Ok, so I took;
36.3+(13.00335*931.5) = 12148.9 MeV and
(14.003241*931.5)+(1.008664*931.5)= 13983.6 and
12148.9-133983= 1834.67 (wrong answer)
so I tired taking out the neutron rest mass because I assume it's moving afterwards...
through the same process I got 895.098 (wrong answer).
Am I going through the correct process to get the resting KE?
Ahh, I just got the right answer, I took
(13.00335+2.0141)-(14.003241+1.008664) = .005546 and
.00546* 931.5 = 5.1661 and
5.1661+36.3 = 41.46, which was the correct answer.
So for a problem like this I just take the Q value, then add that to the incoming KE value?
