Temperature change in Aluminium
  • Thread starter Thread starter Shahni
    Formula
The discussion focuses on calculating the temperature change of a 21 kg aluminum block that absorbs 1.5 x 10^5 J of energy. The relevant equation for this calculation is Q = m x c x ΔT, where Q represents the heat absorbed, m is the mass, c is the specific heat capacity, and ΔT is the change in temperature. To solve the problem, one must look up the specific heat capacity of aluminum, which is necessary for determining the temperature change.
  • Understanding of the formula Q = m x c x ΔT
  • Knowledge of specific heat capacity, particularly for aluminum
  • Basic principles of thermodynamics
  • Ability to perform unit conversions if necessary
  • Research the specific heat capacity of aluminum
  • Practice solving similar problems involving heat transfer
  • Explore the concept of thermal energy and its applications
  • Learn about different materials' specific heat capacities for comparative analysis
Students studying physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer in materials.
Shahni
The question is "A 21 kg aluminum block absorbs 1.5 x 10^5 J of energy. Calculate the change in temperature."
m = 21 kg
Q=m x c x T ?
m = 21 kg
Q=m x c x T ?
You use the formula you listed under "Relevant equations"
It is often listed as Q=m x c x ΔT to emphasise the change in temperature. You will also need to look up the specific heat capacity of Aluminium [the c].
NOTE: metal names end in "ium" Calcium, Sodium, Ferrium [Iron] etc. That is why it is actually Aluminium :rolleyes:
  • · Replies 16 ·
