How Is Entropy Calculated for a Heating Copper Block?
The discussion focuses on calculating the change in entropy for a 2 kg block of copper when its temperature is increased from 25 degrees Celsius to 100 degrees Celsius. The specific heat of copper is given as 386 J/kg·K, leading to an energy absorption calculation of 57900 J. The change in entropy is derived using the formula ΔS = Q/T, resulting in a final value of 155.09 J/K, indicating an increase in disorder as the temperature rises.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with the concept of specific heat capacity.
  • Knowledge of entropy and its mathematical representation.
  • Basic calculus skills for integration.
  • Study the derivation of the entropy formula in thermodynamics.
  • Learn about the specific heat capacities of various materials.
  • Explore the implications of entropy changes in physical systems.
  • Investigate reversible and irreversible processes in thermodynamics.
Students and professionals in physics, engineering, and thermodynamics who are interested in understanding heat transfer and entropy calculations in materials.
Quipzley
Find a) the energy absorbed as heat and b) the change in entropy of a 2 kg block of copper whose temperature is increased reversibly from 25 degrees C to 100 degrees C. The specefic heat of copper is 386 J/kg * K.
a) Q = 386 J/kg *K * (373 K - 298 K) * 2 kg = 57900 J
b) the change in entropy = integral(dQ / T). I'm unsure of how to integrate to be able to have a usable formula?
Since [itex]\Delta Q = cm\Delta T[/itex]:
[tex]\Delta S = \int_{Ti}^{Tf }\frac{\delta Q}{T} = \int_{Ti}^{Tf } \frac{cm\delta T}{T}[/tex]
Note:
[tex]\int_{Ti}^{Tf }\frac{\delta T}{T} = ln(\frac{T_f}{T_i})[/tex]
AM
To solve this problem, we can use the formula for the change in entropy, ΔS = Q/T, where Q is the energy absorbed as heat and T is the temperature in Kelvin. We already know the value for Q from part a) of the problem, which is 57900 J. Now, we need to find the temperature in Kelvin at both the initial and final states.
Initial temperature, T1 = 25 + 273 = 298 K
Final temperature, T2 = 100 + 273 = 373 K
Substituting these values into the formula, we get:
ΔS = 57900 J / (373 K) - 57900 J / (298 K) = 155.09 J/K
Therefore, the change in entropy for the 2 kg block of copper is 155.09 J/K. This means that the disorder or randomness of the system has increased by this amount as the temperature was increased from 25°C to 100°C.
10K
