Kinetic Friction, Undefined Pushing Force, Find Normal Force.
The problem involves a crate being pushed at constant velocity across a rough, horizontal surface. The crate's weight is given as 73N, and the coefficient of kinetic friction is 0.41. The push force is applied at an angle of 37 degrees below the horizontal, and the objective is to determine the magnitude of the normal force.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to use the equations of motion and friction to find the normal force but is uncertain about the magnitude of the push force. Some participants suggest drawing a free-body diagram and analyzing the x- and y-components of the forces involved.
Participants are exploring different interpretations of the forces acting on the crate. Some guidance has been offered regarding the need to account for the angle of the push force and its components. There is recognition of the relationship between the forces but no explicit consensus on the final approach to finding the normal force.
The original poster expresses frustration over previous attempts and acknowledges that they are missing the magnitude of the push force, which is critical for solving the problem. There is also mention of the context being an exam question from a previous semester.
Saraballs
A crate is pushed at constant velocity across a rough, horizontal surface by a push force P. The crate has a weight of 73N. Coefficient of kinetic friction between the crate and the floor is 0.41. Vector force P points at an angle of 37 degrees below the horizontal. What is the magnitude of the normal force?
fk = μkN
constant velocity indicates v0=vfinal and therefore a=0
no movement in the y direction, therefore ƩFy=0
These are random things that I have found online but I'm not sure if they're true:
Fcosθ=f (The horizontal component of the push force is equivalent to to friction)
The problem is, I don't have the magnitude of the push force. I don't know where to go from here, but I have tried many things.
To find the kinetic friction:
fk = μkN
=(0.41)(73N)
=29.9N
Using Fcosθ=f, I assume that 29.9N is the horizontal component of the push force. I then find the vertical component of the push force:
Py=29.9N*tan37
Py=19.6N
I then add this to the weight to find the Normal Force:
73+19.6=92.6NThe Normal Force is not 92.6N. This problem is from an exam I failed last semester, and I have the correct answer now, but I can't get to it.
Thank you in advance, for anyone who can help me out.
Welcome to Physics Forums.
You'll need to draw a force (free-body) diagram for the crate, and then look at x- and y-components of the net force.
Thank you.
I have drawn a free body diagram.
There is a Push force which is exerting some negative vertical force, some positive horizontal force (this is at a 37 degree angle).
There is a frictional force pointing in the negative x direction.
There is mg (73N as specified in the question). The Normal force is what is unknown. I can upload a picture of this free body diagram if this helps more.
Alright, after spending about 8 hours trying to figure this question out, googling, flipping thru my textbook, asking all my friends, I've finally got it (with some help from the online version of my textbook-- I had to piece together several different problems to get this).
Recognizing that there is a=0,
ƩF_x = Pcosθ-f_k = 0
Therefore, Pcosθ-(f_k)(μ_k)(N)=0
ƩF_y = Psinθ+N-mg = 0
Therefore, N=mg-Psinθ
** Recognize at this point that N (normal force) is not mg. So we are missing the magnitude of the force P, and N (which will be the final answer).
-- Start by finding P.
Substitute (mg-Psinθ) for (N) in the first formula [Pcosθ-(f_k)(μ_k)(N)=0].
-- From here you should be able to isolate and solve for P. This is the magnitude of the Push force.
-- Next, using the angle, you can extract the vertical component of the Push force (P).
-- You should be able to solve for the normal force from this.// Side note, signing up and asking a question here was honestly my last resort. It was just ironic that I happened to give in 1 hour before I solved this problem. I will definitely be back for more help during the next semester of Physics, though. Just got to get thru 5 more months of it.
Good job, but note that it should be -P sinθ for the y-forces, since the crate is being pushed with a downward angle. That will change things, but your method is sound.
Good job recognizing that constant velocity → a=0
Saraballs said:
Thank you.
In general, listing the forces as you have done, along with having drawn the figure for yourself, will usually be good enough.
Good luck with the rest of your course!
  • · Replies 20 ·
  • · Replies 57 ·
  • · Replies 16 ·
