Solving Homework Q: Bullet & Block Impact Velocity
  • Thread starter Thread starter Afro_Akuma
    Lost
The problem involves a bullet impacting a wooden block, where the bullet passes through the block and causes it to slide on a rough surface. The key parameters include the mass and initial velocity of the bullet, the final velocity of the bullet after passing through the block, and the distance the block slides before coming to rest. The subject area pertains to dynamics and collisions, specifically focusing on the conservation of momentum and energy considerations in the context of a collision.
  • Mixed
  • Participants discuss the setup of the problem, considering the types of collisions (elastic vs inelastic) and the need for additional information such as the mass of the block and the coefficient of friction. Some suggest using energy considerations related to the distance the block slides, while others question the assumptions about the collision type.
The discussion is ongoing, with participants exploring different interpretations of the problem. There is recognition that additional information is necessary to proceed, particularly regarding the mass of the block or the coefficient of friction. Various approaches are being considered, but no consensus has been reached on how to solve the problem definitively.
Participants note the absence of the mass of the block and the coefficient of friction as critical missing information that complicates the problem. The implications of the bullet passing through the block in a negligible time frame are also under discussion, affecting the energy transfer and friction considerations.
Afro_Akuma
Having missed most of this material, I am finding myself at odds wih the last question of a homework assignment:
A bullet of mass 4.0 g moving horizontally with a velocity of 500 m/s strikes a wooden block, initially at rest, on a rough wooden surface. The bullet passes through the block in a negligible time interval, emerging with a velocity of 100 m/s and causing the block to slide 40 cm along the surface before coming to rest. With what velocity does the block move just after the bullet exits?
Can anybody suggest a good way to set up this problem?
Are you given the coefficient of friction of the surface?
I don't think you need the coefficient of friction to solve a problem like this. This is a type of collision question. Since there are two types of collisions (elastic and inelastic), there are two ways of setting up the problem. We'll just treat yours as an elastic collision since the bullet and the block don't remain stuck together. So, set it up like this:
m1v1 + m2v2 = m1v1' +m2v2'
m= mass in kg
v= velocity-->(v2' is the velocity of the block after the bullet goes through, which is what you want to find)
Try plugging some of the numbers into this formula and solve for v2'.
O.K. wait a sec...do you know the mass of the block?
I figured we didn't have the mas of the wooden block, otherwise the "it moves 40 cm part" would be useless and pi = pf would be all there is to the problem.
My idea was to use the fact that in moving of 40 cm, the friction does a work equal to the variation of kinetic energy. If we know the coefficient of friction mu, then
[tex]W = 40cm*m_2g \mu = \frac{1}{2}m_2 v_2'^2[/tex]
and we can isolate v_2' as a function of mu.
OK then we do need mu. Woops...my mistake. I wasn't sure how to take the "40cm" part into account. There isn't another way to do it without mu then, is there?
The collision can't be treated as elastic, since the bullet does deform the block. That takes energy, which will have to come out of the initial kinetic energy of the bullet. Kinetic energy therefore cannot be conserved, so the collision cannot be elastic.
It does seem to me that more information is needed here. Clearly, the amount of friction is going to make a difference. Since the bullet passes through the block "in negligible time", friction will not matter greatly in the amount of energy transferred to the block. The distance the block will slide, then, will depend only on the force of friction. If we knew the mass of the block, we could determine from that the velocity of the block: the distance it slides would then tell us the force of friction and, therefore, the coefficient of friction. Alternately, if we knew the coefficient of friction, we could determine the force it exerts. Given that, we could find the velocity and, hence, the mass of the block. Without one or the other, though, it seems to me the problem is insoluable as stated.
10K
