Optical absorption liquid vs solid
This discussion focuses on the optical absorption characteristics of potassium permanganate in both liquid and solid states. The user seeks to understand the differences in light attenuation when a laser beam passes through a saturated solution versus a single crystal of the same substance. Key factors influencing absorption include crystal structure, molecular orientation, and polarization effects. The Landolt-Börnstein series is recommended as a valuable resource for finding tabulated absorption data for various materials.
  • Understanding of optical absorption principles
  • Familiarity with potassium permanganate and its properties
  • Knowledge of crystal structures and their effects on light interaction
  • Basic concepts of laser optics and attenuation measurements
  • Research the Landolt-Börnstein series for optical absorption data
  • Study the effects of crystal orientation on light absorption
  • Explore the differences in refractive index between liquids and solids
  • Investigate the impact of molecular polarization on optical properties
Researchers in materials science, optical engineers, and anyone studying the optical properties of liquids and solids, particularly in the context of light absorption and attenuation measurements.
jaisale
I'm looking for information about absorption of light per unit (atom, molecule, stoichiometric) in a liquid vs solid. For instance, imagine a unit cube filled with a saturated solution of, say, potassium permanganate, and shine a laser beam through it from bottom to top and measure the attenuation. Then, evaporate the water and form a single crystal of p.p. in the bottom of the cube, and measure the attenuation of the beam again.
In both cases the laser beam passes through the same number of the relevant atoms or molecules. Is there any way to reason whether a given substance will have less, the same, or more attenuation between the liquid form and solid form? It is easy to find data on the different index of refraction between liquids and solids, but are there books or internet resources that make it easy to find optical absorption for various liquid/solid or solution/solid forms of various crystals?
Thanks in advance, of course.
Well, there may be all kind of differences. E.g. due to the crystal structure the absorption may be different along different directions and for different polarizations of the crystal due to orientation of the molecules, interaction of the ions or internal fields in the crystal.
Obviously absorptions for crystals have been tabulated. A good starting point is landolt börnstein.
