Quick question on fluids and buoyancy
  • Thread starter Thread starter testman2k
    Buoyancy Fluids
The discussion revolves around buoyancy and fluid mechanics, specifically focusing on the relationship between buoyant force and gravitational force in the context of a floating submarine.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the equivalence of buoyant force and gravitational force, questioning the necessity of using specific formulas for buoyancy. They discuss the implications of object volume and density in calculations.
Participants are actively engaging with the concepts, raising questions about the formulas and their applications. Some guidance has been offered regarding the context of floating objects and the importance of using submerged volume versus total volume.
There are indications of missing information regarding the specific conditions of the problem, as well as discussions about unit consistency in calculations.
testman2k
Hi, i have a quick question regarding the above subject.
If
F(b) = (rho) (V) (9.8)
and F(b) = F(g)
and F(g) = (m) (9.8)
then wouldn't F(b) = (m) (9.8)
A = B
B = C
Therefore, A = C
I don't see why there should be any problem...
Then why do we need to use the formula:
F(b) = (rho) (V) (9.8) to find the buoyancy force when we could just multiply its mass by 9.8 ??
Frog knows.
Really, what is the context of the question? If the object is floating - ie. weight = bouyancy, then obviously compute the weight and you get the bouyancy. Careful with V though - the equation will give you the submerged volume of the object, not the total volume of the object.
the question is:
a submarine with volume(total) 4.67x10^3 and mass of 4.39x10^6 is floating at the surface of sea water, of density 1.03x10^3
a) what is the buoyant force on the submarine?
In this case, we do not have enough information to use the equation F(b)=(rho)(V)(9.8)
since m = (rho)(v) - thus, (rho)=m/v
sub it in and you get
F(b) = (m/v)(v)(9.8)
simplify...
F(b)= (m)(9.8)
another quick question when we plugin values for density for water do we use 1.0 or 1000
Examine the units that you were given. The density of water is 1000 kg/m^3 and 1.0 kg/dm^3 or 1.0 g/cm^3.
If you keep the units consistent, you should be fine.
What are we trying to match the units of density with?
All your other units.
  • · Replies 17 ·
  • · Replies 29 ·
