Waves and sounds, finding the speed of a jet using the speed of sound
The discussion focuses on calculating the speed of a jet at point B using the speed of sound and kinematic equations. The speed of sound at 20°C is established as 343 m/s. The jet's speed at point A is given as 180 m/s, and the problem involves determining the speed at point B while considering constant acceleration. The use of trigonometric principles, specifically the Pythagorean theorem and possibly the law of sines or cosines, is suggested to solve for the distance and time between points A and B.
  • Understanding of kinematic equations, specifically x = 1/2(Vo + V)t
  • Knowledge of the speed of sound, c = 343 m/s at 20°C
  • Familiarity with trigonometric principles, including the Pythagorean theorem
  • Basic concepts of angular frequency and period in wave mechanics
  • Study the application of kinematic equations in projectile motion
  • Learn how to apply the law of sines and cosines in triangle problems
  • Explore the relationship between sound speed and temperature variations
  • Investigate the effects of acceleration on the motion of objects
Students in physics or engineering courses, educators teaching kinematics and wave mechanics, and anyone interested in the practical applications of sound speed in aviation contexts.
atriancarlos
A jet is flying horizontally, as the drawing shows. When the plane is directly overhead at B, a person on the ground hears the sound coming from A in the drawing. The average temperature of the air is 20 oC. If the speed of the plane at A is 180 m/s, what is its speed at B, assuming that it has a constant acceleration?
http://edugen.wileyplus.com/edugen/courses/crs2216/art/qb/qu/c16/ch16p_101.gif
x=1/2(Vo+V)t
V=λ/Period (T)= λ x Frequency
c (speed of sound)= 343 m/s at 20 degrees celsius
T (period)= 2 ∏/ω(angular frequency)
first I tried to use the kinematic equation to find the distance between the points A and B but I am stuck because i need the time in order to find the distance (x) between the two points. I think I need to use the pythagorean theorem because the angle made by point B is 90 degrees and I am giving the angle of the observer on the ground as 36 degrees, meaning that the last angle should be 54 degrees to add up to 180 degrees. Do I need to use the law of cosines or sines since I know three angles? any help is appreciated
Can't view your picture.
In your image, the right triangle has sides (using your formula), (v_0 + v)*t/2 , h, c*t.
The length (v_0 + v)*t/2 is related to the length c*t using some trig. t will cancel.
This is late, hope it helps.
