Find the Sum S(n): Expression & How to Use LaTeX
  • Context: LaTeX
  • Thread starter Thread starter primarygun
    Sum
The discussion revolves around finding a function to express the sum of squares, specifically the series 1^2 + 2^2 + 3^2 + ... + n^2. Participants also inquire about using LaTeX for mathematical expressions.
  • One participant asks for the expression of the sum of squares and how to use LaTeX.
  • Another participant suggests that the sum can be represented as \sum_{n=1}^\infty n^2, but this is challenged as it is not an infinite sum.
  • A participant emphasizes that the sum is from 1 to n and points out that an infinite sum diverges.
  • Suggestions for keywords to search for related discussions include "sum of squares."
  • One participant introduces Newton's finite difference method as a way to approach the problem, providing a detailed breakdown of differences and polynomial representation.
  • Another participant expresses a desire to have learned calculus to better understand the discussion.
  • A complex method involving telescoping sums and various summation techniques is presented as a way to derive the sum of squares.
  • One participant shares a unique approach involving combinations of increasing three-digit numbers to express the sum of squares.
Participants do not reach a consensus on the best method to express the sum of squares, and multiple competing views and approaches are presented throughout the discussion.
Some mathematical steps and assumptions are not fully resolved, and the discussion includes various methods and perspectives without a definitive conclusion.
primarygun
How can I find the a function to express the sum of a function, like
[tex]1^2+2^2+3^2+...+n^2=?[/tex]
What's the expression?
Anyway, how can I use latex?
Thanks for advice.
Isn't that sum just [tex]\sum_{n=1}^\infty n^2[/tex]?
Read this thread for info about LaTeX.
It's the sum from 1 to n of r^2, not an infinite sum, especially an infinite sum that obviously diverges.
Seach these forums for it as it comes up a lot.
With what keywords?
Thanks. They are useful
For a problem like that, "Newton's finite Difference" method, a variation on Taylor's polynomial works nicely.
Make a list of values and repeated differences:
n y(n) dy d2y d3y d4y
0 0 1 3 2 0
1 1 4 5 2
2 5 9 7
3 14 16
4 30
Where the number in each "difference" column is the difference between two successive numbers in the previous column. Of course, since the y value itself is gotten by adding squares, the first difference is just the square itself. The second differences are just odd numbers and the third differences are the same: 2. All succeeding differences are 0.
Newton's polynomial now is y+ (dy)n+ (d2y/2) n(n-1)+ (d3y/3!)n(n-1)(n-2)+ ... with the ith term being (diy)/n! n(n-1)..(n-i+1)
Here, that gives 0+ 1n+ (3/2)n(n-1)+ (2/6)n(n-1)(n-2)= (n/6)(6+ 9n- 9+ 2n[sup[/sup]-6n+ 4)= (1/6)n(2n2+3n+1)= (1/6)n(2n+1)(n+1).
One can show that the sum of "kth" powers is a polynomial of degree k+1.
I wish I have learned calculus.
One way to do it.
[tex]\sum_{k=1}^{n} k^2[/tex]
[tex]\sum_{k=1}^{n} k^2 -k + k -1 + 1[/tex]
[tex]\left( \sum_{k=1}^{n} k^2 - k - {1 \over 2} + 1 \right) + \left( \sum_{k=1}^{n} k - {1 \over 2} \right)[/tex]
[tex]\left( \sum_{k=1}^{n} k^2 - k - {1 \over 2} + {1 \over 3 } + {2 \over 3} \right) + \left( {1 \over 2} \sum_{k=1}^{n} 2 \left(k - {1 \over 2} \right) \right)[/tex]
[tex]\left( \sum_{k=1}^{n} k^2 - k + {1 \over 3} \right) + \left( \sum_{k=1}^{n} {2 \over 3} - {1 \over 2} \right) + \left( {1 \over 2} \sum_{k=1}^{n} 2k - 1 \right)[/tex]
[tex]\left( {1 \over 3} \sum_{k=1}^{n} 3k^2 - 3k + 1 \right) + \left( \sum_{k=1}^{n} {1 \over 6} \right) + \left( {1 \over 2} \sum_{k=1}^{n} 2k - 1 \right)[/tex]
[tex]\left( {1 \over 3} \sum_{k=1}^{n} k^3 - (k-1)^3 \right) + \left( \sum_{k=1}^{n} {1 \over 6} \right) + \left( {1 \over 2} \sum_{k=1}^{n} 2k - 1 \right)[/tex]
[tex]{k^3 \over 3} + {n \over 6} + {n^2 \over 2}[/tex]
If you're wondering how [tex]\sum_{k=1}^{n} 2k - 1 = n^2[/tex]
[tex]\sum_{k=1}^{n} 2k - 1[/tex]
[tex]\sum_{k=1}^{n} k^2 - k^2 + 2k - 1[/tex]
[tex]\sum_{k=1}^{n} k^2 - (k^2 - 2k + 1)[/tex]
[tex]\sum_{k=1}^{n} k^2 - (k-1)^2[/tex]
[tex]k^2[/tex]
This last step is called telescoping property of sums, it was also
used in the last step of the first proof, for the leftmost term.
[tex]\sum_{k=1}^{n} (a_k - a_{k-1}) = a_n - a_0[/tex]
After reading the website last night, I got it.
1^2+2^2+3^2+4^2+5^2...x^2
all you have to do is look at increasing three digit numbers, and the amount of combinations in an increasing three digit number is 1+2+3+4+5+6+7+(1+2+3+4+5+6)+(1+2+3+4+5)...
but there is any easier way to express this, it could be 9(8)(7)/6 because an increasing number is only one out of six.
now look 100(1)+/99(2)/+98(3)+/97(4)/+96(5)+/95(6)/...+/1(100)/= 102(101)(100)/6
and 99(1)+97(2)+95(3)+93(5)...+1(50)
so the terms in / / are going to be repeated again, and you divide that by two so you get the series below, and you get (102)(101)(100)/24 as the sum which is (2n+2)(2n+1)(2n)/24 which is equal to the sum of the nth squares.
kind of a cool way. to find the sum of cubes, use four digit numbers.
9K
