New Reply
A Cannon Fires Projectiles on a Flat Range at Fixed Speed but with Variable Angle
Share Thread Thread Tools
Jan28-12, 10:58 PM   #1
A cannon fires projectiles on a flat range at fixed speed but with variable angle. The maximum range of the cannon is L. What is the range of the cannon when it fires at an angle [itex]\frac{\pi}{6}[/itex] above the horizontal? Ignore air resistance.
2. Relevant equations
Four kinematic equations.
3. The attempt at a solution
I honestly don't know where to start. What exactly does the question mean by the range of the cannon? Is that the horizontal distance the projectile goes?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jan28-12, 11:05 PM   #2
Yes the range will be the horizontal distance. Since projectiles move horizontally at a constant velocity, it is simply calculated by multiplying the x-component of the velocity by the time of flight.
x=v(x)*t
where v(x) means the x-component of the velocity. v(x) = v*cos(theta)
x = the range
The trickier part is calculating the time of flight. This is done by finding the y-component of your initial velocity, then recognizing that the final velocity at landing will be the opposite of this value. Knowing that the projectile will accelerate at -9.8 m/s^2 you can then solve for the time of flight and substitute it back into the first equation.
v(y-final) = v(y-initial) + a*t
v(y-initial) = v*sin(theta)
v(y-final) = -v(y-initial)
Hope that helps.
Jan28-12, 11:08 PM   #3
range is how far away the target is. Given the maximum range is L then they are looking for a percentage of L when the angle is pi/6.
show some work and people will help.
Jan28-12, 11:08 PM   #4
Recognitions:
Yes, the "range" is the horizontal distance the projectile travels.
What angle will produce the maximum range? What is the speed of the projectile if the maximum range is L?
New Reply
Thread Tools
Similar Threads for: A Cannon Fires Projectiles on a Flat Range at Fixed Speed but with Variable Angle
Thread Forum Replies
cannon at rest shot on frozen pond. what is cannon balls v after cannon recoil? Introductory Physics Homework 2
Projectile Motion given starting height, initial angle, and range, find initial speed Introductory Physics Homework 9
Momentum (Cannon fires at angle & recoils) Introductory Physics Homework 5
Cannon connected to spring fires projectile Introductory Physics Homework 26
Algorithm for Cannon Range General Physics 2
