Infinite Sheets of Charge and Conducting Slab
The problem involves two infinite sheets of charge with specified charge densities and an uncharged infinite conducting slab positioned between them. The goal is to determine the potential difference between two points in the electric field created by these sheets and the slab.
  • The original poster attempts to calculate the potential at point S after determining the potential at point P and the charge densities on either side of the conducting slab. They express uncertainty about the energy field's behavior between the two points.
Participants are exploring the implications of the charge densities on the conducting slab and the electric field's constancy between the sheets. Some guidance has been offered regarding the cancellation of charge densities and the behavior of the electric field in the presence of the conducting slab.
There is a mention of the program's feedback indicating that the energy field is not constant between points S and P, which the original poster acknowledges. The discussion also reflects on the assumptions regarding the net charge of the conducting slab.
darwin59
An infinite sheet of charge is located in the y-z plane at x = 0 and has uniform charge denisity σ1 = 0.34 μC/m2. Another infinite sheet of charge with uniform charge density σ2 = -0.14 μC/m2 is located at x = c = 26 cm.. An uncharged infinite conducting slab is placed halfway in between these sheets ( i.e., between x = 11 cm and x = 15 cm). What is V(S) - V(P), the potentital difference between point P and point S, located at (x,y) = (20.5 cm, -15 cm)? (point P is located at (5.5 cm, 0 cm))
I've already solved for the left and right side charge density of the conducting slab to be -0.24 μC/m2 and 0.1 μC/m2 respectively. I've also already solved the potential at point P, being 1.492e3 V (or at least I think I have). What I need help with is finding the potential at point S, more specifically the energy field there. The program tells me I'm on the right track but the energy field is not constant from S to P, which I already know, but I can't figure out how to solve for it.
darwin59 said:
An infinite sheet of charge is located in the y-z plane at x = 0 and has uniform charge density σ1 = 0.34 μC/m2. Another infinite sheet of charge with uniform charge density σ2 = -0.14 μC/m2 is located at x = c = 26 cm.. An uncharged infinite conducting slab is placed halfway in between these sheets ( i.e., between x = 11 cm and x = 15 cm). What is V(S) - V(P), the potential difference between point P and point S, located at (x,y) = (20.5 cm, -15 cm)? (point P is located at (5.5 cm, 0 cm))
Hello darwin59. Welcome to PF !
The charge densities on the on either side of the slab have to cancel, i.e., they have to be equal in magnitude & opposite in sign.
The Electric Field between the two sheets of charge and external to the conducting slab is the same as if the slab were not present.
Thanks for the hospitality!
I'm not sure how I didn't try that out, or how exactly I got stuck down the path that the conducting slab should have a net charge, but I got it. Thank you very much SammyS!
You're welcome.
Most of us try to give "newbies" a warm welcome.
  • · Replies 17 ·
14K
16K
  • · Replies 26 ·
