| New Reply |
Derivation of kinetic energy |
Share Thread | Thread Tools |
| Feb23-12, 05:43 PM | #1 |
Hi everyone,
There are 2 things I do not understand in the derivation of kinetic energy from work: http://www.physicsforums.com/showthread.php?t=111162 (1) W = [itex]\int[/itex][itex]\vec{F}[/itex](t).d[itex]\vec{r}[/itex](t)= (2) m.[itex]\int[/itex][itex]\frac{d\vec{v}(t)}{dt}[/itex].d[itex]\vec{r}[/itex](t)= (3) m.[itex]\int[/itex]d[itex]\vec{v}[/itex](t).[itex]\frac{d\vec{r}(t)}{dt}[/itex]= (4) [itex]\frac{m}{2}[/itex].(v(t1) - v(t0))[itex]^{2}[/itex] Question I: I don't understand why you can just change the division like that between (2) and (3). I know multiplication and division have the same order but they are calculated from left to right. So why can you do that from (2) to (3)? http://en.wikipedia.org/wiki/Order_of_operations Question II: I don't understand why the change in kinetic energy between t1 and t0 is sometimes written as [itex]\frac{1}{2}[/itex].m.v(t1)[itex]^{2}[/itex] - [itex]\frac{1}{2}[/itex].m.v(t0)[itex]^{2}[/itex] E.g. like in http://www.physicsforums.com/showthread.php?t=194461. After (4), it should be [itex]\frac{m}{2}[/itex].v(t1)[itex]^{2}[/itex] - m.v(t1).v(t0) + [itex]\frac{m}{2}[/itex].v(t0)[itex]^{2}[/itex] , right? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb23-12, 05:59 PM | #3 |
| Feb23-12, 06:02 PM | #4 |
Mentor
| Feb24-12, 04:17 AM | #5 |
Re your QI...
I respect your unwillingness to regard [itex]\frac{d\vec{v}}{dt}[/itex] as one thing divided by another, but you might be happier to do this with [itex]\frac{Δ\vec{v}}{Δt}[/itex], and then associate Δt with Δ[itex]\vec{r}[/itex] to make [itex]\vec{v}[/itex]. Only then take it to the limit. I don't suppose this is rigorously valid, but I suspect this is how a lot of physicists justify this sort of transposition. |
| Feb24-12, 02:11 PM | #6 |
Thnx for your responses.
| Feb25-12, 11:49 AM | #7 |
Question II: It is not sometimes, but always, because that is the result of the integration of (3). You own result (4) is incorrect. |
| New Reply |
| Tags |
| kinetic energy work |
| Thread Tools | |
Similar Threads for: Derivation of kinetic energy
| difference between relatavistic kinetic energy and normal kinetic energy | Special & General Relativity | 2 | ||
| Derivation of Kinetic Energy | Introductory Physics Homework | 3 | ||
| Understanding derivation of kinetic energy from impulse? | Classical Physics | 3 | ||
| Ratio kinetic energy of alpha particle / kinetic energy of proton | Introductory Physics Homework | 2 | ||
| Derivation of Kinetic Energy | Classical Physics | 1 | ||
