What is the significance of pH in a basic solution?
  • Thread starter Thread starter Bipolarity
    Ph Significance
The discussion revolves around the significance of pH in basic solutions, particularly in the context of water's autodissociation and the relationship between pH and pOH. Participants explore the implications of these concepts in both acidic and basic solutions, questioning the role of hydroxide ions and the calculations involving pH and pOH.
  • One participant expresses confusion about the meaning of pH in basic solutions, questioning how pH can be relevant when only hydroxide ions are produced.
  • Another participant points out that water always contains both H+ and OH- ions due to autodissociation.
  • A further reply emphasizes that the dissociation constant of water (Kw) supports the relationship pH + pOH = 14, even in solutions other than pure water.
  • One participant seeks clarification on the significance of pOH in acidic solutions and the role of water's hydroxide ions in these calculations, expressing uncertainty about the contributions of acids and bases to pH and pOH.
  • Another participant introduces the concept of equilibrium, explaining how adding an acid affects the concentration of H+ and shifts the equilibrium of water dissociation.
Participants demonstrate a lack of consensus on the significance of pH and pOH in basic and acidic solutions, with multiple viewpoints and questions remaining unresolved.
Participants highlight the dependence on the autodissociation of water and the equilibrium dynamics involved, but do not resolve the implications of these factors for understanding pH and pOH in various solutions.
Bipolarity
I am a little confused about the meaning of pH, especially when you have a basic solution. I know that [itex]pH = -log[H^{+}][/itex], but I don't understand how you can have a pH for a basic solution. Don't basic solutions only produce hydroxide ions?
I know that [itex]pH + pOH = 14[/itex] but why this equation be true for anything other than water?
For example, consider the basic solution of ammonia to produce ammonium ions and hydroxide ions.
[tex]NH_{3}(g) + H_{2}O(l) \rightleftharpoons NH^{+}_{4}(aq) + OH^{-}(aq)[/tex]
Knowing the concentrations and the base-dissociation constant, we could easily calculate [itex][OH^{-}][/itex] and from that we can get pOH, but what is the significance of pH if there is no [itex]H^{+}[/itex] ions?
Chemistry news on Phys.org
Why do you say other than water? Water has its own dissociation constant Kw=10-14=[H3O+][OH-]. Taking logarithm on both sides, I think you would get the same result.
And it is due to the fact that at temperature of your room, water dissociate in the aforesaid proportions; therefore, under aquatic, room temperature, it is always true. If any of the ions are in excess, the equilibrium of the dissociation reaction would shift, so that some of those would recombine and be back to equilibrium. Of course you can analyse the free energy and understand more precisely, but that's not quite relevant.
Thank you for your replies everyone. I do know that water dissociates, but I still don't understand the significance of pOH in an acidic solution and the significance of pH in basic solution.
Acid produces hydrogen ions in water, but the hydroxide ions come from the water and not from the acid? What is the point in counting the water's hydroxide ions toward the calculation of pOH for the acid? I'm not sure I get it... all I know is that water dissociates into both hydrogen and hydroxide ions. But acid dissociates ONLY into hydrogen right? So where does the pOH for the acid come from? And pH for the base? Am I missing something?
Thanks!
BiP
Have you heard about equilibrium?
Water dissociates producing both H+ and OH-. When you add an acid you increase the concentration of H+, shifting water dissociation equilibrium to the left - but there will be still OH- in the solution.
