Calculating Wavelength in Young's Double-Slit Experiment
The discussion focuses on calculating the wavelength of monochromatic light in a Young's double-slit experiment, specifically for the eighth-order bright fringe. The path difference is given as 3.22 x 10-6 m, and the relationship between path difference, wavelength, and order of the fringe is established through the equation sinθ = mλ/d. The derived equation λ = (d * sinθ) / m is confirmed as the correct approach to find the wavelength once θ is determined.
  • Understanding of Young's double-slit experiment principles
  • Familiarity with wave interference and fringe patterns
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to manipulate equations involving wavelength and path difference
  • Study the derivation of the double-slit interference formula
  • Learn how to calculate angles using the small angle approximation in wave physics
  • Explore the concept of path difference in wave interference
  • Investigate the impact of slit separation on fringe spacing in Young's experiment
Students studying physics, particularly those focusing on wave mechanics and optics, as well as educators seeking to clarify concepts related to interference patterns in light.
lolcheelol
In a Young's double-slit experiment, two rays of monochromatic light emerge from the slits and meet at a point on a distant screen, as in the figure below. The point on the screen where these two rays meet is the eighth-order bright fringe. The difference in the distances that the two rays travel is 3.22 10-6 m. What is the wavelength of the monochromatic light?
d=3.22x10^-6
m=8
λ=?
sinθ = mλ/d
well i derived the equation
sinθ*d/m = λ
I'm pretty sure I can figure it out once I get the θ, but I have absolutely no idea how to solve for it in this case.
I'm also not sure if you need y=L*tanθ
any help is appreciated
In the double slit experiment Maxima occur when the path difference between the 2 sources = nλ
That should be all you need !
i don't understand, do u mean
3.22x10^-6/8 = λ
