Dielectric Influence on Series and Parallel Capacitors
The discussion revolves around the effects of inserting a dielectric slab between the plates of one of two identical capacitors in a circuit. Participants are exploring how this insertion influences various parameters such as potential difference, charge, capacitance, and potential energy in the context of series and parallel capacitor configurations.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to determine the effects of the dielectric on the potential difference and charge across the capacitors. Questions arise regarding the constancy of voltage across capacitors in parallel and how changes in capacitance affect charge distribution.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some participants suggest that the voltage across capacitor C1 remains unchanged despite the introduction of the dielectric in C2, while others explore the implications of this on charge distribution. There is a recognition that the dielectric affects only the capacitance of the capacitor it is inserted into.
Participants are navigating through the implications of the dielectric on the circuit without reaching a definitive conclusion. The conversation reflects a mix of understanding and confusion regarding the relationships between voltage, charge, and capacitance in the presence of a dielectric material.
cellphone
http://img99.imageshack.us/img99/763/prob45.gif
Fig. 1 and 2 show a dielectric slab being inserted between the plates of one of two identical capacitors, capacitor 2. Select the correct answer to each of the statements below (enter I for `increases', D for `decreases', or S for `stays the same').
In Fig. 2, the potential difference between the plates of capacitor 2 _______ when the dielectric is inserted.
In Fig. 2, the charge on capacitor 1 _______ when the dielectric is inserted.
In Fig. 1, the capacitance of capacitor 2 _______ when the dielectric is inserted.
In Fig. 1, the potential energy stored in capacitor 1 _______ when the dielectric is inserted.
ΔV = Q1/C1 = Q2/C2 ( parallel )
Ceq = C1 + C2 ( parallel )
C = Cok
Q is distributed evenly over two capacitors in series.
A. Stays the same. ΔV over a capacitance in parallel always remains the same.
B. ΔV = Q1/C1 = Q2/C2, when C2 increases (C = Cok), Q2 will increase as well to compensate. Qnet = Q1 + Q2, this means Q1 must decrease.
C. C = Cok, therefore C increases.
D. 1/Ceq = 1/C1 + 1/C2. when C2 grows larger, 1/C2 grows smaller resulting in a smaller C1. V1 = Q2/(2*C). I've revised this many times and I still can't see what I'm doing wrong. Any help muchly appreciated, thanks!
For B, what's the action of the battery with regards to the potential across C1? Can it change?
Well, the battery emits a voltage that is said to be the same across two capacitors in parallel (or so I was taught and have read), so no the voltage across the two capacitors should not change when a dielectric species is introduced. That being said, doesn't that coincide with what I said above? Thanks for the reply, by the way!
You argued that changing the capacitance of C2 would have an influence on the charge on C1. What determines the charge on C1?
The charge emitted from the battery. When I attempted another answer, I got it right by saying that the charge stays the same. This still confuses me because the voltage shouldn't change, and that being said the charge must change to compensate for the change in capacitance.
Also, if I have the equation ΔV = Q1/C1 = Q2/C2 and CNET = C1 + C2, wouldn't this mean that if even one variable changed (as ΔV is constant), the rest would change?
Capacitor C1 is not changing value. The voltage supply is not changing value. The voltage supply sets the charge on C1.
So despite the fact that C2 is changing due to a dielectric, C1 wouldn't have to change to compensate?
That's right. Only C2 has to make changes to alter its charge to match the voltage supply.
Awesome, thank you so much! The way I was looking at it was the same as having an equivalent capacitance. The same way you'd find one to "shrink" a circuit to find the resultant potential differences and charges across capacitors. So in summary, a dielectric only affects the capacitance of it's capacitor and not those around them?
Correct.
welcome to pf!
hi cellphone! welcome to pf! :smile:
another way of looking at it (have you done the difference between the D and E fields yet?)
is that the D field, which is measured in units of charge per area (C/m²) is the charge per area (Q/A), and is unaffected by anything else …
so D = Q/A for each capacitor no matter what is between them, and then E = D/ε :wink:
(btw, are you ok now on your other thread?)
